Question about Radio Communications
ICOM IC-F21 (400-430MHz): Programming problem
When I program my radio using CS-F11 software, i get a warning message (error message). And the TX and RX LED indicator are blinking alternately. Please advise...
  • nanzc Jan 15, 2008
    My software is working fine because i could program my other radio.
  • copierfixer Apr 28, 2009
    I have the same problem trying to program Bearcom by Icom IC F21S two channel radio. Using CS-F11 program RS232 cable on laptop. Can't go from the radio or to the radio I get this:
    Check the following
    -The RS @32C Port Settings
    -Cloning Cable Connections
    -Appropriate cloning sorftware for the transceiver is being used
    -The revision number of the transceiver
    But I also have a Regular IC F21S radio (not bearcom) that works just fine with the software
    ....Help
    Problem Solver:
  • 12 Answers
When programming the radios the green light will flash when uploading or downloading data. The red light flashes when the battery is low. Maybe they are happening at the same time. As for the error message I would need to know what it said. Carl
Posted on Sep 14, 2009
    Problem Solver:
  • 7 Answers
May your software be corrupted.Re-install it
Posted on Jan 14, 2008
SOURCE:
Icom F1721 w/ cs-f70/1720 software - can read the f1721's information (win7 with USB to serial com link), but can't read/write programming.
This is a commercial radio and often, the programming for the is not as easy as with an Amateur radio. I haven't worked on this radio specifically, but I do remember with the commercial radios that I repaired that often there was a jumper that had to be removed or installed to be able to program them. This prevented the customer from getting into the programming and screwing things up, plus it is ******* for them to do this unless they are licensed to work on commercial radios. My guess is you have to find out if this is in fact the case. A good place to look for radio manuals is www.mods.dk.
Sep 26, 2016 | Icom IC-F1721D P25 VHF Mobile Radio, 256...
Icom programming
I looked up ICOM 2710 on the icomamerica.com web site and found ICOM IC-2710H which is a ham radio transceiver.
Jul 14, 2014 | Radio Communications
Cloning CS-F50 using usb port
Do you have a USB programming cable for the radio? If not, get a USB to serial adapter and plug between the computer USB and serial programming cable. Adapter driver will help with the interface.
Jun 09, 2014 | Icom Cs-f50 Programming Software Ic-f50...
How do I reset the F221 to factory settings. I cloned the unit with V1.6 of the programming software with updates that included turning on the user start password and now the box will not communicate with...
F121 VHF, F221 UHF they both use the latest Version 1.7.
For F121 Factory default as follows:Open your CS-F100 software, enter RX TX frequency below, and write to the radio.Ch1: 136.100 MHzCh2: 155.100 MHzCh3: 173.900 MHz
For F221 Enter RX TX frequency belowCh1: 440.000MHzCh2: 460.000MHzCh3: 489.000MHz, then write to your radio
Or you check from this site:http://www.two-way-radio-tools.com/icom.html
HP
Feb 04, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
1 have a icomf3s-3 32 channeli can ony see 16
Hi, the problem is you only have 16 channels programmed in the radio. you can program the full 32 if you have- the software, http://hamradio.online.ru/ftp/dw.php?icf3f4.zip . And the programming lead- http://cgi.ebay.co.uk/USB-Interface-cable-for-ICOM-IC-v8-Radios-6-030_W0QQitemZ330356207021QQcmdZViewItemQQptZUK_ConsumerElectronics_SpecialistRadioEquipment_SM?hash=item4ceac3adad&_trksid=p3286.c0.m14
Hope this helps.
Aug 16, 2009 | ICOM Informatique Icom Radio IC-F3, IC-F4,...
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Mar 13, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Radio Communications Logo
1,725 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
