Question about Radio Shack Cinego D-1000 Multimedia Projector
SRC button on cinego projector will not read source
For the past year I have been using my Cinego projector and laptop to successfully do a powerpoint presentation course in Driver's education to high school students. This past weekend the SRC button on the projector stopped functioning properly. It would not read the source for the VGA input on my laptop. It kept defaulting back to the DVD status. My Fn and F5 buttons are set correctly. Can you help me solve this problem.
Mark Stein
[email protected]
    Brigadier General:
  • 6,966 Answers
Three (3) things you can try:
1. Lower down the Screen resolution of your laptop as well as the Color quality and the Screen refresh rate before doing the Fn + F5. If it works, adjust thereafter;
2. Do a soft (Factory) reset of your Cinego in the in the Management Menu (credit to Cooljazz); and/or
3. it is just "slow" in sensing the presence of a VGA source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait or ...Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 14, 2008
6ya staff
SOURCE:
My cinego is stuck on search mode. From the moment it turns on it starts searching as if I was holding the searching button down . The modes all run but search will not stop.
Try unchecking the "auto source select" box. Push the setup button on your remote (bottom row, second from the right), use the arrows (7, 0 , 9, or 5) to move across to "management" and down to "auto source select." Make sure it is unchecked (by higlighting it and pressing Enter, which is the 8 key).
Jul 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Cinema projector
please start your laptop first and then your projector-----test after that---press fn key with f4 or f5 or f6 or f8 if no display---and check your input source(compter)in our case.
Sep 22, 2008 | Radio Shack Cinego D-1000 Multimedia...
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego D-1000
I have the same problem with my cinego.
Maybe we should all sue Radio Shack to take these machine back
This problem is wide enough to issue a recall.
Dec 24, 2007 | Radio Shack Cinego D-1000 Multimedia...
Cinego Projector to a laptop
Describe the connections available to you on the projector.
Jul 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
I have problem wiht Cinego D-1000
While it is frozen on that "Searching" screen, hold the SRC button down on the actual projector for an extended time. Then after letting it up, hit it briefly one or two times until it finds a source. Make sure that under Projector Setup/Management/ "Auto Source Select" is checked. This brought my Cinego back from the dead.
Jan 08, 2007 | Radio Shack Cinego D-1000 Multimedia...
294 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Pie-man
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
