Computers & Internet Logo
Anonymous Posted on Nov 26, 2009
Wont boot puts screen up with phoenix award winning bios setup press f1 or del to enter setup done that next window gives multiple options, standard cmos features etc. at the bottom of the page option save&exit setup i clicked this but it just takes me back to first screen phoenix bios setup
clb199
Level 2:
Scholar:
  • Expert 164 Answers
  • Posted on Nov 26, 2009
clb199
Expert
Level 2:
Scholar:
Answers
164
Questions
Helped
57815
Points
496
This is a bios screen.
when your computer has no operating system to boot to, it hangs at the Bios screen.
either your hard drive is dead, your boot sector of your hard drive is corrupt or you need to reinstall your Operating System
Skips CMOS setup
The BIOS information is typically found at or near the top of the POST screen for a very short time
ALR PC non / PCI =CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaultsusing the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
this will reset your cmos
The boot order was saved in the bios and now when i press f2 it wont let me in
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
My desktop 4210 is in paused mode how do i fix it
Step 1:
Award BIOS: (Del) or (Ctrl)(Alt)(Esc) Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
1helpful
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Can't setting bios
ALR PC non / PCI = CTRL+ALT+ESC
Award BIOS = DEL
during the boot process you will see on the screen to press a certain key usually delete or F2 to enter setup
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
hope this helps
2answers
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
1helpful
2answers
How do i change the boot sequence. I have the Compaq sr1630- win xp os. Installed new hard drive after disk to disk copy. System has the Phoenix - Award Bios CMOS topman
During boot there should be a notifaction at the bottom of screen saying something like "Press Del for bios and F10 for boot menu" or something like that with other keys. If there is a boot menu option press the corresponding key and you will enter the boot menu. Here you can set the drive you want as first, second and depending on the motherboard third boot device.
If there is no boot menu option, enter the BIOS and go to advanced BIOS options, or something like that. There should be located a submenu called boot sequence, in which you can adjust the boot sequence too.
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
ALR PC: (F2) or Ctrl+Alt+Esc
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
1helpful
Unable to get into BIOS SETUP
hi there,
On most systems, the key or key combination to press to enter the BIOS program is displayed on the screen when the system boots up, at the time when the BIOS is ready to enter Setup.
take a look at some default keys:-
  • {Delete} (modern Award and AMI BIOSes)
  • {F2} (modern Phoenix BIOSes)
  • {Ctrl}+{Alt}+{Esc}
  • {Ctrl}+{Esc}
  • {Alt}+{Esc}
  • {Ctrl}+{Alt}+{S}
  • {Insert}
  • {F1}
Top Medion Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
SmartAviator
SmartAviator
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
