Question about Liebert PowerSure PSI UPS System
Lieber PowerSure UPS
my pc UPS losses output power and i can hear infinite beep from the device..plss help
    Problem Solver:
  • 7 Answers
How does it react when you simulate a power lose? Unplugg it from the wall to test it to see if it turns to battery power. If the unit goes to the battery backup normally then check to see if it has a reset button on the unit. Please let me know what size unit it is.
Posted on Jan 14, 2008
  • Bill Cooley Aug 21, 2012
    I am also having a similar problem with the 350 VA UPS. Power loss to the facility and now the beeping
A continous beep sound is hear in my ups..........wat shall i do now
Continuous beeping can be an indication that the battery needs replacing, especially if you have had this UPS for awhile
Feb 22, 2013 | APC Back-UPS ES 350 - UPS ( external ) -...
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I hit the button to turn it on it will stay on for awhile and then it will start beeping really loudly an shut off
With your UPS turned off, unplug your PC and all other devices from the unit. Then turn the UPS on. If it still beeps and shuts off your UPS internal battery may need to be replaced or you have an internal UPS failure. Look for a red "battery alarm" light on the front of your UPS.
If the UPS does not shut down with all devices disconnected from it, Power off your monitor and look on the back of the monitor for a label which will tell you the amount of power it requires (probably 100 watts or less). Plug the monitor's AC power cord into your UPS and turn on your PC and monitor. With the UPS plugged into the AC line you are not using the internal battery and the UPS should remain on and your monitor should be working. If it shuts down you have an internal problem with the UPS.
Now unplug your UPS from the AC line (simulating a power failure) Your UPS is rated at 350 watts. Accordingly it should easily support the 100 watt load of your monitor. If the UPS continues to provide power to the monitor for 1 or 2 minutes down it's an indication that it's working properly and the COMBINED LOAD of your monitor. PC etc. when plugged into the UPS is exceeding the 350 watt capacity of the UPS. You will have to disconnect 1 or more devices from the UPS.
NOTE: Never plug a laser printer into an UPS.
If the UPS immeadiately shuts down after disconnecting it from the AC line with only the monitor plugged into it you have a bad battery.
If you found this information to be helpful to you please return to the FixYa website and rate me.
Regards,
Yavacotech
Dec 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
My Liebert PSA itON 600 UPS keeps beeping when i turned it on
To figure out what's wrong with the UPS, first you have to do a few things.
When calculating the rating a UPS can handle, it's voltage x amperage. If it's Watts multiply the number by 1.67 to give the rating of the device.
Add up all the devices (use the power supply rating in the computer) as well as any other device, and add them up.
If this rating was exceeded, then you have overloaded the UPS. If it was too long that you did this, then you wore out the battery.
When a UPS beeps even when not connected, that means the battery is very weak.
If the battery is more than 3 years old, it will need to be changed. If the online tests of the unit were done and the battery doesn't need replacing, then other parts of the UPS need fixing.
Check the battery.
Jul 27, 2009 | Liebert PowerSure ProActive PSA700 UPS...
Help with my liebert powersure interactive 1000?
The wiring fault light indicates that the polarity of your power outlet is wrong (positive and negative wires have been inverted) or that the ground is missing/faulty.
This have nothing to do with the configuration of the UPS. Unfortunately (for liability reasons), I have to tell you that the only person who can fix that is an electrician.
Just for testing, try plugging it into another power outlet elsewhere in your house to see if it is any different.
Feb 21, 2008 | Liebert PowerSure InterActive PS1000MT UPS...
Liebert Power Sure UPS
the battery is bad, you will need to replace the battery or the whole unit. you can find batteries on ebay. just source the model number. also depends on the size of the unit. you may need to just replace it...just a better value to do it that way.
good luck
K.
Jan 14, 2008 | Liebert PowerSure PSI UPS System
Liebert PowerSure PSI UPS System Logo
517 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
