Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Constant blank streaks on both printed and photocopy items.
We have blank streaks about an inch apart accross all print outs and photocopies. We have cleaned photocopier and print heads, what else can we do?
    Problem Solver:
  • 6 Answers
Hi Wooky,
The streaks are likely only present beside a bold character or heavy print section of the doccument content.
The print head assembly is likely carrying an obscure hair or piece of fluff back and forth which is acting like a paint brush.
The offending fibre is mos likely attached to the adge of the cartridge or print head carriage assembly. Also check the dervice station where the catridge docks when not printing as it can store fibres in the capping and wiping components especially if the printer is situated low to the ground where fibres tend to fly or you have fine haired pet like a cat, rabbit or toy dog.
Best way to clean is to trick the printer to unpark carriage (open top door to trigger carriage to present itself) then uplug power. Now you can move things at will to clean up with moist cotton buds (clean water is best).
Good luck
Posted on Jan 14, 2008
Canon ir 1024 photocopier photocopy but the paper is blank what can be the problem
if print from computer ok than problem on scanner or both blank problem on high voltage
Jul 20, 2016 | Canon IR1024 COPIER FOR 220 VOLTS
My espon ME320 does not print but can photocopy and scan.
Get another driver for the printer from Epson web site. If that do not work call the Epson technical support or leave them an E-Mail.
Mar 25, 2012 | Office Equipment & Supplies
It won't scan or photocopy.
This issue might occur if the scanner bulb is damaged. Please repair your printer in a service center.
:) Dr Tony
May 25, 2010 | HP PSC 1315 All-In-One InkJet Printer
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
Prints and photocopies blank pages
a bet your problem is the drum cartridge,on it´s back exists a lever,rod, or something like that ,if it´s bent will not open the laser and give blank pages ,open the left door and check if it´s straight.
Jun 12, 2009 | Canon iR 2022 Printer
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Photocopier prints red
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print best, etc.
Apr 25, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark X 83 will photocopy but not print
Ok thanks for the info:
Do you still have the the Installation disk for your printer?
Apr 04, 2008 | Lexmark X83 All-In-One InkJet Printer
Sharp AM-900
It is either in the path of the scanning like the platen glass or if it is a MFP check the little glass strip on top of the glass thats where auto doc feeder scan from, or the imaging drum/toner is bad, or the transfer belt is bad or worn and there could always be a roller causing the marks, or the fuser itself can be bad. there are just too many things that can cause that. is it streaks with no print or is it printed then scrated like streaks?
Aug 06, 2007 | Sharp (SHRAM900) All-In-One Laser Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
186 people viewed this question
Ben Johnson
