hi Justine. There some moments when the steering wheelbecomes stiff and hard to turn. From irregular servicing, lack of fluid oil to low tyre pressure or bad wheelalignment, any of these could be the cause. ... Under normal circumstances when the car is in good condition, the steering wheel is always flexible when turning.11 Sep 2014
if steering wheel becomes very stiff when turning wheel or corners the problem might be slipping power steering belt or partial plugged pressure line at power steering pump open cap and watch and see if there is and abnormal noises/good luck!
It should like you may have a leak if it took a whole litre. Once you fix the leak you may also find the power steering pump still makes noise. This can be repaired by replacing the pump. I hope this helps.
Hi, what you need to do is put the key in the ignition then grab hold of the steering wheel then whilst trying to turn the key you need to turn the steering wheel to the left or right it may be a bit stiff but once its moved it should free the lock, so try turning the wheel to the left and right as hard as you can whilst turning the key doing this should free the steering lock and get it started.
also try putting the key in the ignition the other way round and then give it a try.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
bad electrical signal to the pump. pumps thinks its going fast. the valve that controls the fluid flow to make steeering stiffer at higher speeds is confused.
use electrical contact cleaner and d-electric grease to fix contact problems.
pop the hood and cleans as many connections as possible, let dry and apply a small amount of di-electric grease to those connections, then re-connect the plugs. even do the dme connections to the main wiring harness.
this will solve many electrical contact problems seen in older cars.
Have the belt checked. Your Tercel has one (or more, sorry I'm not sure) belt that spins the pulleys of different engine components.See if you can turn the wheel while someone looks at the belt. Does it seem to 'slip' or squeal, screech? One of the components is the power steering pump, another is the air conditioner. If the belt is slipping the engine components won't be 'powered', or in other words, they won't work properly. It sounds like it could be a problem with a belt, is there any unusual noise when turning the steering wheel when it becomes stiff? Did both problems occur at the same time? Please let me know so I can provide more info if needed. countrycurt0
