Question about Creda W100FW Front Load Washer
Identifying and locating the fuse
I have a front loading creda 1000 eco washing machine that will not spin at all. the timer seems to work fine, but the drum does not move at all through any of the cycles. the belt is in tact, but the motor isn't moving. last time i tried it, it was turning a for a little bit. again nothing. i don't know wether it may be the brushes or a balance sensor or what. Please Help!!!!!
Comment by credawash, posted on Jan 01, 2008 got the brushes in, and wow! things started going well. ran a couple of spin cycles as directed, and before i put the lid back on i dropped a tool into the machine. i was leaning over with my arm inside , and i guess my belt switched the machine on without knowing it, and must have moved the door release cable into contact with the motor and got a good spark that shot out of the bottom of the motor, now the motor isn't working again. might there be a fuse i could have blown? or did i toast the motor. was a really stupid thing to not have unplugged the machine. PLEASE HELP!!!!!!!!!
Comment by credawash, posted on Jan 02, 2008 Ok, I think i judged where the spark came from. when looking down into the guts of the machine from the load side, there is a electrical board (the brains i would assume) on the right side. behind it i noticed that there is a burn mark on the sheet metal. I am sure this panel must have pushed up against the sheet metal when i was trying to retrieve my tool. Is the panel history? how spendy could it be?
Comment by credawash, posted on Jan 14, 2008 i have no idea how to identify the fuse on this thing. auto fuses sure, but on this thing, i am not at all familiar as to what i am looking for, nor where it might be located. would it be on the board itself? please help!!
Still need a solution for this problem?
Try our Premium Assistance plan
Solution #1 posted on Jan 14, 2008
tech17
  • credawash Jan 14, 2008
    i am not seeing any fuse on the panel. there is a breaker box in which the machine plugs into. maybe somewhere else in the machine?
    Scholar:
  • 196 Answers
Yes, the fuse is on the motor control board and normally is or looks like glass auto buss fuse.
Posted on Jan 14, 2008
My Creda simplicity 1000 washing machine wasn't draining or spinning now there's no power light coming on and does nothing when i turn it on is it un repairable
It could be a lot of different things. Maybe the timer. If you know someone who has a volt meter and knows how to use it. Find you machine with a Google search, look for trouble shoot washing machine timer. That's the way I would do it. You want to look for a open in the electrical system *{the switch} like a broken wire inside the switch. Make sure to unplug the machine first. You won't need the power on for the first tests. A volt meter can be purchased for under $10. and any home repair store or box store.
Dec 14, 2014 | Creda W100FW Front Load Washer
The fast spin cycle on my creda 1000 will only spin slowly,leaving clothes wet,any thoughts
This machine has a variable spin-speed setting. You can set the spin-speed RPM (between OFF and 1200RPM) using the smaller dial located next to the main wash programme selector dial.
I hope I'm not stating the obvious, but appliance "faults" are often simple and don't require taking the machine apart or calling a service engineer. If you've already tried the above suggestion and your washing machine is still spinning slowly, please post back and I will try to assist you further.
Regards,
BElectric
Nov 27, 2010 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Where is the filter
The filter is located at the rear`of the washer.
To access it, remove the rear lower panel.
You will see a large black hose, remove hose from bottom of tub, and you will find the plastic filter inside, remove filter and clean.
Refit filter and hose, and test.
If it still does not spin, then you need to check the brushes.
If you require info on how to check and change them, then let me know.
Please rate my fixya solution.
Thanks.
THanks.
Feb 10, 2009 | Creda W100FW Front Load Washer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Creda 1000 Superspeed, stacked: Motor does not run
Sounds like you have motor problem, I suggest u check the brushes in the motor, most likely cause of problem.
Also check that the belt is still on the motor.
Dec 03, 2008 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Did i fry the panel?
that should be the motor control unit it has a fuse in it but will probably have to replace the whole board disconnect the wires and ohm the fuse
Jan 14, 2008 | Creda W100FW Front Load Washer
it is the carbon brushes in the motor. there cheap and easy to replace. go on give it a go
Dec 11, 2007 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
118 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
matt
matt
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
