Question about Western Digital (WDXB1200BBRNN) 120 GB Hard Drive
Auto Play My external runs Auto Play and finds multiple files and wants to know what to do with them. I store music and game files that are called upon from programs on Windows on internal HD. This auto play comes up at any given moment. Is there a way to disable autoplay in the registry?
  • 1 more comment
  • KickPeddle Jan 14, 2008
    I did that already and the AutoPlay window still comes up, scans folders for about 50 sec. and shuts down. When you are in a game and this happens in the background, the game freezes and needs to be restarted. When it happens with my media player playing, it makes the player stutter the same part of the song over and over until you hit the stop button.
    I typed that in but got an error saying it was unable to locate. Is this a command for Vista? I am running XP Home. I know how to shut down autoplay for the cd rom through the registry editor. But do not have autoplay in the registry entry for the WD external.
  • KickPeddle Jan 15, 2008
    Thanks for the info.
    I appreciate it greatly!
    Problem Solver:
  • 15 Answers
With the drive plugged in, go to My Computer, and right click on your drive. Select Properties from the menu, and click on the Autoplay tab. Click on the "Select Action to Perform..." and select "Take No Action" from the menu. That should stop Windows from ever asking you what to do with the drive in the future.
Posted on Jan 14, 2008
  • Paul Buszta Jan 14, 2008
    Since that didn't work completely, you can try another probable fix for the problem:
    Go to start menu / Run and type "gpedit.msc" in the dialog box and hit enter.
    Under Administrative Templates there is a folder named System, click on that and double click on "Disable Autoplay". In the dialog box that appears, check the radio button for Enabled, and then select "All drives" in the dropdown that is labeled "Disable Autoplay on: "
    Oh, unfortunately the gpedit.msc only works in 2000 Professional, XP Professional, but I'm not sure if it is in Vista. You can disable autorun with Microsoft's PowerToys, which can be downloaded here.
    There is an AutoPlay option under My Computer in Power Toys that allows you to disable Autoplay by drive letter. Hope this fixes your problem.
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Tip
How to Download Super Mario Run on Android Right Now?
Super Mario Run is out now for iPhone as an App Store exclusive, but Android users want to play Super Mario Run too. We outline how you can play Super Mario Run today, and everything you need to know abut the game including the Super Mario Run Android release date and price.
Top Tricks and Tips to Download Super Mario Run on Android - Pre-register in Google Play Store
An announcement on Nintendo of America's Twitter account is that Android users can pre-register on Google Play and will receive a notification as soon as Mario's auto-runner becomes available for download. So, if you want to follow Super Mario Run news for Android, you can now go to pre-register Google Play. Although this is not a direct and effective tip for downloading Super Mario Run on your Android devices, it may be the safest one without efforts. If you want to try another ways and are ready to undertake any risks of receiving warning messages, being banned, the second method is just for you.
Top Tricks and Tips to Download Super Mario Run on Android - APK Files Downloaders
The second method is a bit tricky, all you need to do is find APK downloader website, which enables you to download the latest and hottest apps, games from Google Play. But this method is risky of being carried viruses on your devices.Download Free Android Apps Games
on Jan 16, 2017 | Cell Phones
Windows media player won't play any audio selections , says can't find files
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
I downloaded the new version of ITunes. I have an external hardrive (Seagate Brand )where the songs were stored and now it is saying it can not locate any of the songs. I have tried to find the file...
Seems like the update when you updated it changed the actual location where it looks for your music. To get all of your songs to match the library click on the advanced menu and select consolidate library. The reason for the black tab is you have mp3's in multiple spots (external drives or different folders) that haven't been added to your main library. If you always want to add songs automatically to your library, go to itunes preferences>advanced and check the Copy files to itunes Music folder when adding to library.
Jul 07, 2010 | Dell Computers & Internet
I have a UTStarcom Shuttle. I am trying to play to play music
Put a microSD memory card (limit 4GB) in the phone. Take a few pictures and make a short video .Use the phone menu to transfer the pictures an video to the external memory card. Use the media player to watch your recorded video. Try to play music and you will get a no content found message. Now, turn off the phone, remove the memory card and place it into an adapter that will connect to a computer by usb port. Windows should recognize it as a removable drive. If you look at that drive in Explorer you will see 3 folders. Pictures are in my_pix. Videos are in my_flix. Transfer .mp3 files to the my_music folder. When you put the card back into the phone you can play the mp3 files with the media player. Yes, I did this and it works.
Feb 23, 2010 | UTStarcom Cell Phones
External Hard Drive not recognising music files
Before opening the external hard drive, try auto playing the external hard drive, usually auto play recognizes the music files and asks u if u want to play it or not
Nov 21, 2009 | LG 10X DVD IDE 452000078
How do I delete multiple songs from my sansa fuse mp3 player?
HI,
To delete multiple songs you need to connect your Sansa Fuze to your computer and delete the files from the Music folder.Just press hold CTRL and select the song files with your mouse which you want to delete and then press the DEL button.
If you need any more help let me know.
Thank you
Aug 13, 2009 | SanDisk Sansa e260 MP3 Player
Auto Play
* Click Start
* Click Run
* Enter GPEDIT.MSC
Group Policy mmc will popup. On left panel:
* Double-click Computer Configuration to open submenu
* Double-click Administrative Templates to open submenu
* Double-click System to open submenu
* Double-click Turn autoplay off option which will be near the bottom of the list in the right panel.
The default is the Not configured. Set it to Enabled."
May 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hearing a "music" when a call is made
I think I know this one, so please rate this a FixYa!
Do not pick up the handset. Press PROG press each line button TWICE. Press the Down arrow on the NAVIGATOR button. It will play ring tones in choices 21-30. Press ENTER to save.
You have to do that for each line you want to ring differently.
Carl
Mar 20, 2009 | Panasonic KX-T7630 Corded Phone
Lacie d2 DVD RW external importing music CDs into iTunes
Apple late Thursday posted iTunes Repair Tool for Vista 1.0, a software update that fixes iTunes issues reported by new Windows Vista users. According to widespread reports, music purchased from the iTunes Store could not be played in iTunes on the new Microsoft operating system released this week. Users reported that they received a message saying their computer was not authorized to play the purchased tracks. “The iTunes Repair Tool for Vista 1.0 will repair permissions for important files required by iTunes to play your iTunes Store purchases,” Apple states in the brief release notes.
Feb 17, 2008 | Computers & Internet
Western Digital (WDXB1200BBRNN) 120 GB Hard Drive Logo
521 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
