Question about Tomtom GO 300 GPS Receiver
Tom Tom Touch Screen
My touch screen has one of the buttons stuck down so i can't switch screens
  • Anonymous Mar 08, 2009
    TOMTOM ONE touchscreen needs to be calibrated or something. doesn't flash on where i touch on the screen?
  • Anonymous Apr 12, 2009
    First my screen froze so I deleted the application and reloaded it as instructed on the Tom Tom site. Now it seems the next big problem is that the touch screen does not work where I touch it. I haven't dropped it - it's stored in my center console. What to do if the touch screen goes wacky?
While l was cleaning my tom tom 300 touch screen, some of the cleaning solution got in between the glass layers and I now have a spot that keeps moving. my question is there any way to open this up and dry this out or is the screen toast. Thanks mukat
Posted on Jan 15, 2008
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Touch screen stops working
common problem. might need tho be calibrated. turn off front power switch and then the rear main power switch. turn on the front switch, hold down energy save button and copy button, turn on rear switch and continue to hold energy and copy buttons until the screen displays an X in the top left of the display. immediately release the buttons and touch the X with a pen/pencil/pointed object. the X will move to the center and them to the bottom right of display. touch the X as it moves position. the copier will reboot and the display may work. if not, replace the touch screen. part #n2baayy00771.
Sep 13, 2014 | Panasonic WORKiO DP-C322 Printer
My tagital tablet stuck on android screen
Hold down the power button for 30 seconds and then turn it back on.
May 01, 2014 | Tagital TM 7" Android 4.0 4GB MID...
Acer Iconia Tablet A500 won't boot past the Acer logo screen
How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Mar 06, 2014 | Acer Iconia Tab A50010S32u Notebook
My tomtom one 140 Touch screen is not working any more the touch screen is non responsive i have connected the tomtom to the computer and carnt connect to the computer because i carnt use touch screne and...
It may be something stuck between the screen and the edge of the screen. When this happens with a foreign object, the screen cant sense anything because the debris is holding it down. Clean around the edge with a q-tip and window cleaner and maybe a toothpick and try again.
Feb 19, 2018 | Tomtom ONE 140 -S Car GPS Receiver
.legge@hotmail.comMy designer 1 Touch Screen
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Mar 22, 2011 | Husqvarna Designer I
If i turn on my celphone the bootup shows only touch pro 2 then does not load
this is a quick fix but unfortunatlly all the info will be lost on the phone. its called a hard button reset this helps when its stuck on the main screen, bootscreen or in this case the touch pro 2 screen. i found this info at http://forums.t-mobile.com/t5/T-Mobile-Touch-Pro2/touch-pro-2-stuck-in-boot-screen/m-p/186641#M1996.
: While the TP2 is turned off, press and hold down the Talk/Send key and the End key and press the Power/On key simultaneously. A screen that comes up has a warning, then tells you to press the Volume Up button to reset to factory fresh. Try it, if you haven't yet.
Message Edited by MCbrian on 09-14-2009 10:47 PM
this will work 100%!!! i hope this helps!!
Dec 24, 2010 | Cell Phones
HOW TO CALIBRATE MY DESIGNER 1 SCREEN the screen is off if i touch program nothing happens and the arrows are off to the right side
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again,and it should be fixed. Regards, Cathy.
Sep 15, 2010 | Husqvarna Designer I
Touch screen will not respond. It's stuck on
Other sites suggest you power it off. Then hold down the '?' button when you power it back on. Then it says you can select the 'A' button. This is supposed to reformat the stylus.
Jul 17, 2010 | LeapFrog Leapster 2 Learning System
Wont power off
you need to hold the button down until the screen shows a bar that says 'slide to power off' then it switches off completely.
Aug 03, 2008 | Apple iPod touch
Tomtom GO 300 GPS Receiver Logo
1,258 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
