Question about Konica Minolta Magicolor 2530 DL Laser Printer
My magicolor 2530 DL
My printer ate one of our labels. We have been able to get the label out, but it now is smoking. It started with labels, now it is smoking. I think it is going down the wrong road.
Now it says fatal error 24H. Is that bad?
    Problem Solver:
  • 6 Answers
Hi Condeleeza,
Normally smoke would be caused by label residue being left on the fuser rollers, I am assuming your use of the word label is correct and not a transparency (which is a common jamming source in laser printers) especially when someone mistakenly puts a inkjet transparency through a laser printer or mistakenly puts a clear plastic divider sheet through.
If you are sure all of the original label has come out and there is was no residue left directly on the fuser rollers, and the fact you now have smoke and an error code (which I do not have access to find service codes for Minolta), I suspect the fuser assembly is overheating now which is causing the error message (after probably 10 seconds after switch on from cold). This could mean the temperature sensor monitoring the fuser temp is either not touching the fuser due to label fragment lifting sensor off fuser roller surface or sensor is bent or damaged due to label revolving aorund or subsequent removal efforts.
Take a closer look and see if you can find a stray fragment stuck to a thermocouple sensor wiping against the fuser roller. Failing this then you probably need to send into service and ask for a quote to repair. Be aware that the fuser may have become scratched or otherwise damaged depending upon your label removal techniques....over zealous use of letter openers, nail files and small screwdrivers have destroyed many a good fuser assembly.
Good luck
Kiwi-Mark
Posted on Jan 14, 2008
6ya staff
SOURCE:
Magicolor 2530 dl is giving a service code 0BH
To reset after malfunction has occured,turn the power switch OFF and then ON again.2_4_2013_7_57_57_pm.jpg
Jan 29, 2013 | Konica Minolta Magicolor 2530 DL Laser...
Printing problem on a Konica Minolta 2530DL. Was printing fine until we printed a set of thick labels. Now the print quality is really poor on the right side of the paper. It is both streaking and...
sounds like a lable has gotten stuck in the fixing unit, you may need a tech to remove it, do not use any sharp tools to remove it ,this could cause damage to your roller,
good luck, tinyman
Jul 19, 2011 | Konica Minolta Magicolor 2530 DL Laser...
I have a Fatal Error Code: 17H Can you help? It is a Magicolor 2530 DL color printer.
Check your toner cartridges, one of them is seized up. Remove all cartridges and turn the gear on the right side backwards ( counterclockwise) about 10 times and see if it turns smoothly. I don't know why but 90% of the time its the cyan that gets stuck.
Jun 11, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2530 DL Laser Printer: reset image drum 2530...
I had this same problem however I was using the Magecolor 7450. I was trying to print a C5 postcard and the right hand side of the document was getting cutoff (aprox 2 in). Changing my Paper-Type settings on the printer from "Postcard" to "Any" magically fixed the problem.
I hate this printer.....
May 18, 2010 | Konica Minolta Magicolor 2530 DL Laser...
I have white streaks on every color on a 2530 dl magicolor
There is a glass strip, take out the drum, inside on the front side it's about 6" x 1/2" just wipe with cotton and alcohol
Jun 17, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Instructions for Fuser Unit Change - Konica 2530DL
Send me you email at dhudson at Gmail dot com, and I will reply with the manual attached. It is a very involved process, that, having done it, would not ever want to do again.
Apr 17, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Where is the drum reset fuse located on the Minolta 2530 DL print
you can find all details with picture shot on following website:
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2530dl/user_e.pdf
please post back if any changes and vote all answers.
good luck
Feb 07, 2009 | Minolta magicolor 2350 Laser Printer
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
175 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
