When i plug it it it says not reconised? can someone tell me y and hw to fix this problem?
i have been using it 4 about a month now with out any problem and suddenly it just stoped working.
i need it to work as alot of data was stored on it can someone please help?
It could be that the PCB or the connection within the external casing has a problem.
Try disassembling it and putting the Hard Disk into another external case to see if the disk is okay, if it is then viola! you have your data back.
If that was the case, the driver could be corrupted. try uninstalling then reinstalling it.
When you plug it in, does Windows XP ask you to install the driver or outright tell you that it is not recognized?
To uninstall the driver
- Plug the Device
- Go to Control Panel
- Click on System
- Select the Hardware Tab
- Click on Device Manager
- The device will have a ? indicating its status. Right-mouse click on this then select Uninstall.
- Shutdown your PC. Unplug the device.
- Restart your PC. Run the Installer that came with your Harddisk. When you have finished installing it, plug in the Harddisk.
Hope this helps
Uninstalling it would allow a new driver to be installed so it would kinda make it a fresh start.
it cant be that beacse i have anther two computers in the house that i have tryed it on ad it is working fine.
it was working on this one fine to but now has suddenly stoped:(
i need it to work on this one cse i use tthis one to transer stuf to ohter computers and all my files are on this computer:(
i also made sure the usb port was working by plugin in mp3 player and that worked fine:)
could it be i need a new driver or something?if anyone can help me i would be very greatful.
cheers
please help thanx
Ok i will try this could u tell me how to do that?? i think i knw but want to knw anyway just inace i do something rong and make the problem worse:(
thanx 4 all ur help so far:)
Hey That sounsd like it may work bt the one problem is it did not come wtih any disc to install driver?the first time i used it it just worked? so do u think this will still work?or just make thigs worse if i uninstall?
