posted by teeksas on Jan 14, 2008
my printer won't load paper from the tray. Initially it gives an indication that the paper is out, then when I hit the resume button, it indicates a jam. When I open the tray, the paper has started to load, but it stops. Nothing is obstructing the path. I can feed single sheets in the slot, just can't use the tray. Any suggestions?
Comment by teeksas, posted on Jan 14, 2008
Kind of surprised, not much dirt came off, but it sure worked immediately. Thanks so much for the help.
Best Solution
Sounds like the pickup roller is worn or dirty. Try cleaning the pick up roller for the tray. If this doesn't work the pick up roller will need to be replaced.
Rating Locked! (?) teeksas has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for IBM Infoprint 1412 Laser Printer
Email this problem
Email this problem
Can you Help with these Printers problems?
Factory reset for IBM Infoprint...
I have turned off the web GUI... Answer This...
Ibm infoprint reseter
I've ibm infoprint 1412. I try... Answer This...
Repair Service
Find Printer Repairman Near You:
