The dryer just stoped working it has power to the unit because the light inside works but when you close the door and go to pull the knob out to start it does nothing cant figure out please help
i have the same problem. getting power to the dryer )matag atlantis gas) light comes on when you open door. try to start by pulling up knob... nothing happens. suspect thermal fuse/ need to know quickest way to get to thermal fuse so i can replace. tried going though back, but too difficult. help!!
AnonymousFeb 27, 2009
i have the same problem, when i pull the knob nothing happen and i found the thermal fuse and changed it. Still, nothing happen... Please help... i have the same problem, when i pull the knob nothing happen and i found the thermal fuse and changed it. Still, nothing happen... Please help...
You can't post conmments that contain an email address.
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Hello, To remove the front open the door and remove the screws from the door hinge,then remove the screws from the other side as if the door were mounted to that side. Place a putty knife in the seam between the front panel and the cabinet at the upper corners of the front panel and pop the panel off from the retainer clips that are mounted to teh cabinet the top of the panel will become free so ya can pull it off from their.
sounds like you possibly have a bad ignitor take the front off by removing 4 screws but leave the door on be careful not to touch any wires close the door like you normally would turn unit on watch the flume tube what happens?
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power with a voltmeter or by plugging something else in. Sometimes
the power cord disconnects or burns at the dryer, if this is the
case, the wiring and the terminal block must be repaired or
replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the
door switch if found defective.
Most dryers have a door switch actuator lever - when you close a
dryer door, it presses against the lever, which actuates the door
switch. If the lever is broken, the switch would not activate and
the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch
assembly and it is recommended to get the whole assembly since there
is almost no price difference between the door switch assembly and
just the lever.
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
