Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark printrio x1185 just keeps on blinking doing self test...
I got this printer more than a year ago and it works well for the whole year of usage but when i changed a new batch of both cartridges (as in new & a not refill) the problem began. Everytime i switched it on, i heard a snapped sound or lets just say, a "bang" sound like the printer is smashed to one side of the printer casing and then it displayed the printer problem saying:
"make it sure
- the catridges are snapped in place
- that no objects blocked its movement"
I already cleaned the cartridges where the ink flowed and the printer head too but still the same. I did a self-test printing -- i unplugged the printer and unhooked the usb cable then took both cartridges out. i plugged the printer back then pressed the green button and hold paper feed button but it just kept on blinking. does it means to say, the whole printer is messed up
  • shawawee Jan 20, 2008
    thanks mechanic688 for the help but still the problem is the same -- the initialization of the printer is just a "bang" sound hitting the other side of the printer and the green button keeps on blinking afterwards. nways, bunch of thanks.
    thanks, mechanic688. i did try your posted solution but still the problem is the same -- the initialization of the printer is just a "bang" sound hitting the other side of the printer and the green button keeps on blinking. Nwayz, bunch of thanks.
  • 204 Answers
Hi, on my older Z series printer, as it got older I took some 3in1 oil and a Q tip and applied just a little oil to the slide rods or bars that the cartridges slid back and forth on. They get quite dry with the paper dust and time. Also here is a link to Lexmarks tech site. Hope this helps,, Mechanic
http://support.lexmark.com/static/229-1-0-435.html
Posted on Jan 17, 2008
6ya staff
SOURCE:
HOW DO I FIX A SHORT CIRCUIT ON A LEXMARK X1185 PRINTER?
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please contact Lexmark tech support.
Sep 30, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Need driver for lexmark printrio p3150 cannot find old cd
You can download the printer driver (Windows & MAC) for your model Lexmark from the Lexmark WEB site
Aug 27, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
GREEN LIGHT KEEPS BLINKING PRINTER DON'T PRINT
hi rudy, thank you for using fixya.
when you said a green light was blinking was it the power light or another green light on the printer?
i strongly suggest that you refer to these links to have it fixed if it is a blinking power light.
For instructions on how to clean the ink cartridges: http://www.fixyourownprinter.com/forums/printer/26642.
For a diagnostic procedure: http://www.annoyances.org/exec/forum/winxp/1073811565
For instructions on how to un-install and re-install the print drivers and other Lexmark software problems: http://www.techspot.com/vb/archive/index/t-10556.html
otherwise, we are looking forward to your reply.
regards,
voodoo
Apr 14, 2009 | Computers & Internet
Do u need the cd to make it work
As any other hardware device, you Lexmark X1185 All In One printer does need a software to work with your computer. Normally this software is comes along with the printer, at the time of purchase. In case, If you have lost the CD, no need to worry as Lexmark provides the drivers and softwares free of cost at their website. Please follow this link to download the Lexmark driver software for your printer.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
please follow this link and enter the product name as X1185 in the "Search By Model" field and click on search. This will take you to the download page where you can download the software for your X1185 All In One.
Good Luck & Merry Christmas!
Dec 06, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
My Lexmark X1185 will scan but will not feed to print
You probably need to adjust the roller or do an alignment. Your owners manuel should have the info on how to do this.you can probably clean the roller . If it shiny it will not pull up the paper. Check it out.
Oct 29, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
How to install a Lexmark X1185 PrinTrio printer without cd?
You can download the software for this printer from this link , just select the operating system that your computer is using http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:435:0:0
Don't forget to rate the solution FIXYA thank you.............
Oct 21, 2008 | Office Equipment & Supplies
Lexmark x1185 driver needed for mac os x...
goto cnet.com and search for your printer then driver.they may be third party drivers but they are updated.happy new year!
Dec 30, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
173 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
