Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Speaker buzz The left speaker of my SONY KV-27FS100L TV has a very annoying buzz with certain sounds.  I have not played the TV too loud but it sounds like the speaker may be blown.  The problem does not occur all the time -- only with certain sounds -- both during dialog and music.  Is there anything I can do about it?
  • TomMan Jan 15, 2008
    I read your solutions and took the back off the TV (mostly). The speaker looked OK, as far as I could tell. I spoke to a repair shop and they felt the problem could indeed be capacitors, as Shuttle83 suggested. I am planning to bring the TV into the shop but I have not been able to get the back of the TV back on fully. The bottom of the plastic shell has spread out and I can't get it into place. I plan to wrap a strap around the bottom and bring it in, unless you guys have another suggestion.
    Genius:
  • 1,139 Answers
Hello TomMan,
I would suggest looking at the speaker first to see if it is torn, if it is that's your problem, however if the speaker is not torn, you should then use a audio signal generator and an oscilloscope to view the output at different audio frequencies and levels, This will give you an idea about the source of the buzzing sound. Check for bad capacitors, sometimes these can cause problems.
If you do not feel as if you can do these tasks, get a TV repair shop to check into this problem.
Thank you,
I hope this helps,
Shuttle83
Posted on Jan 14, 2008
  • 2,427 Answers
Well yes your speaker is damaged, the cone actually has a tear, so audio that has low base or high pitch will cause distoration..
Simply remove it, take it with you and buy a similar one.. Same size, same watts, same ohms and just put the new one in.
speakers are standered only brand names are different..
BTW if you feel that you dont want to purchase a new one, simply stick the tear with duct tape, or you can hot glue it together.. If its plasctic, plastic weld works good(ask for it at a hardware)..
  • 1 more comment
  • Rishi Roshan Ali Jan 14, 2008
    hey did you view your suggestions ?
    Did the suggestion work or would you like more advise
  • Rishi Roshan Ali Jan 15, 2008
    Try laying the tv screen down, and put the buttom part on first then the top..
Sony KV-27V10 Lound Buzzin When Screen Full Or Bright
Check for any faulty electrolytic capacitors in the main power supply regulator section.
Dec 22, 2012 | Sony KV-27V10 27" TV
Need Comcast remote code for sony trinitron KV27FS100L
These are the codes to check. 10000, 10011, 10273, 10353, 10834, 11317, 11400, 11685, 11786, 11791, 11904, 11925
Sep 15, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Bad cable input connector?
try use vedio input for work....or use vcr ant in vcr vedio output to tv...
no need replaced tv
Aug 13, 2009 | Televison & Video
Buzzing sound wyen volume is high.
If you have a cable box on the TV, make sure the volume on the cable box is turned all the way up. If you do not have a cable box, some TV's seem to have a annoying buzz louder than others.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-27FV17 27" TV
Buzz in Samsung Digital when DVP-NS57P Sony is played back?
Greetings,
Check the audio connection, the port on the TV might be grounded.
While playing, try moving the connection in the port.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 08, 2008 | Sony DVP-NS575P DVD Player
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
Sony kv 32ts36_speaker sound is distorted
the speakers can only be accessed from the inside of the set. try using the sound Field button on the remote ( the one with the music symbol). change to effects off it may be in surround mode and causing the speaker to buzz.
May 02, 2008 | Televison & Video
Sound at power on
The sound you are hearing is the degausing coil which will vibrate for a second when the tv is turned on. This part demagnetizes the picture tube and this sound is really quite normal. Depending on the position of this coil it may vibrate against the front cabinet of the tv and may sound loud at times. If this really bothers you then you need to have the rear cover removed and have it repositioned a bit do it won't vibrate so loudly. Or you can enjoy the buzz for the short time it happens and not worry about it.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
