A full feature software and driver package for Windows 7 is not
available for your product.However, the Windows 7 operating system installed on your computer
contains a basic driver solution for your product.
With the basic driver, the buttons on the product might not function and
some of the advanced product features are not available. However,
using the workaround procedures in this document, you can still print
from a software.
The full feature software for your printer would be released around Jan 2010...once you install the full feature software for the printer, you would get back all the features as in XP.
SOURCE: Ink levels do not show on Windows 7
This is most probably due to the fact, that you are using a driver built into Windows. It's a basic driver and doesn't include the print monitor or other fancy stuff.
You can go to epson.com, choose support & drivers, and find what's available there for your model.
SOURCE: Ink Levels not showing
try uninstalling the driver from add and remove program: epson printer software.
and we need to completely trash epson files on yur computer:
**printer should be directly hook up on your computer via USB if its on a network status monitor will not actually show up:
**is this the only epson printer that you have on your system? if it is then we can go ahead and delete registry info:
Now we need to remove specific references to the product in the registry.
1. Click on START, then RUN.
2. In the RUN window, type in REGEDIT and press OK.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look at the column on the left.
9. Click on the “+” sign next to HKEY_CURRENT_USER
10. Click on the “+” sign next to SOFTWARE
11. Click on the “+” sign next to Epson
12. Click on the “+” sign next to PRINTER
13. If you see a reference to your printer's model, right click and delete it.
14. Click on the “-“ signs next to PRINTER, EPSON, SOFTWARE, HKEY_CURRENT_USER to close up this branch.
15. Click on the “+” sign next to HKEY_LOCAL_MACHINE
16. Click on the “+” sign next to SOFTWARE
17. Click on the “+” sign next to EPSON
18. Look for a folder with the name of your printer model. Right click on it and Delete it (if you don’t see it, then don’t worry about it).
19. Scroll down and look for a folder named PRINTER and click on the “+” sign to the left of it.
20. Look for a reference to your printer model. Right Click on it and delete it.
21. Click on the “-“ signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to close up this branch.
22. Close the registry editor.
reinstall driver from epson website: support.epson.com
SOURCE: when i print with my epson stylus photo r230 using
Are you able to print? If you are able to print, you probably just need to download the Monitor Status Program that works with Windows7, if any is available. Good luck!
SOURCE: Epson Stylus C86. In XP, the status monitor
Please get the correct driver here :
www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__mcjhgtd34
