Question about Bosch 24 in. SHV99A13UC Dishwasher
Dishwasher starts, then won't move on from the "Empting" portion of the cycle
Our 1.5 year old Bosch starts normally, but won't move to the next portion of the cycle. It also ran for a short time when the door was open, something it has never done. It won't let water in, but the computer thinks it is going through a full cycle since it shows the amount of time left. I shut off the power to the unit for about 1 hour, thinking it would reset, but it did not. Any help?
I am having trouble with my 5 year old Bosch. When I turn it on it is only on when the door is open. When I shut the door the computer believes it is off. I had a technician come and he tested the switch (which was fine) and said the problem must be in the computer. Then then quoted me $350 to fix it. I would rather buy the computer myself @ $120 and install it. What is your opinion?
Posted on May 19, 2008
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
I have just moved into a resale home{two years old} and the bosch dishwasher has a terrible odor what do i do?
Works for me, empty the dishwasher of any dishes, silverware, pot or pans, get (2) jars of "Tang" orange drink. Use (1) jar to fill the soap dispenser and poor the rest into the bottom of the dishwasher.
Run the dishwasher through a normal wash cycle with no heat/dryer time.
Run a second time if necessary. The orange juice acid will dissolve the build up in the dishwasher and rinse it away. It also smells good when your done.
For regular maintenance, repeat once every 3 months or so. It will not harm the dishwasher and will keep the interior components fresh and clean.
Good luck.
Oct 23, 2009 | Bosch Dishwashers
Bosch dishwasher Start Process
lol...yes this is normal for a Bosch. They have several "safety" measures incorporated into their dishwashers. Look on the bright side they are one of the very best dishwashers on the market and are known for their longevity and quietness.
Jul 31, 2009 | Dishwashers
Cycle time
yes its dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHV99A13UC Dishwasher Logo
173 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
