Question about D-Link DP-300U (DHDP300U) Print Server
Wrong Port when printing
I've got two printer: HP LJ 5100 and HP LJ 1200. I connect 1500 to LP1 and 1200 to LP2. It's oke with 5100 but when adding LJ1200, it took a long time to finish and when printing test page or anything, it had no respond and all the things printed out by HP 5100. I couldn't understand why this happen? Please help!
  • Anonymous Mar 02, 2008
    same
    Sergeant:
  • 179 Answers
Assuming you mean you are connecting to two separate parallel ports, then your bios settings may have not been set correctly(duplex operation - bidirectional data allowed) or your ports may have been moved by other added hardware, ie your bios may be poor at doing that especially if the parallel ports are on add in card. but since you gave us none of that information, i would try uninstalling both then just add the 1200 first on the first(other) LPT. see what it manages on the one that works on its own. if its ok which it should be then try adding the 1500 after see what happens to both then.
Posted on Dec 19, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: HP LP1020
It seems that I found an imperfect solution. When you intall the printer on your PC and print a testpage, the firmware is sent from PC to printer and is stored in the printers internal memory. When you unplug your printer from your pc and plug it in on your printserver it should work fine as the firmware has been loaded alraedy. You can't switch of the printer nor the printserver or the firmware needs to be uploaded again via your printer. There is no way at the moment to load the firmware upon booting of the printer by the print server. Hopefully this issue will get resolved in the near future.
Posted on Oct 03, 2007
Anonymous
  • 8 Answers
SOURCE: Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Posted on Jan 04, 2008
Anonymous
Users need Rev B hardware to use LJ 102x printers
Posted on Jul 04, 2008
yashan.co.in
  • 202 Answers
SOURCE: Printer prints multiple pages with DPR1260 print server
hi dear,
you have to see, When you give the print command how many pages are set to print in printing option of the page and you told about test page, it set to one as default.
Posted on Jul 28, 2008
Anonymous
SOURCE: I cannot print using DP-G310 print server
Sorry but P1005 does not come with its own processor to work of a Print Server, it needs PCs processor to process the printed file and send it in a specified format to it. This makes it cheaper for HP to make printers and sell at a margin because their is no processor in them. You have to get a printer which has a processor to work with a Print Server for instance look for Hp 1300 or HP 1100 series
IAK
Posted on Feb 05, 2009
20.0004 error on hp lj m2727
Not enough memory to run the print job.
Try adding more memory to the printer or simplify the
thing that you are printing
Dec 14, 2011 | HP Laserjet M2727nf Multifunction Printer
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Have to keep setting up HPLJ 5P on a USB port everytime I print!
    1)right click the my computer icon
    2)click properties and then click hardware n go to device manager.
    3)uninstall all usb ports and then scan for hardware changes
    4)ur pc will detect your printer and ask for printer drivers
    5)re load drivers and your pc will communicate with your printer
    6)for reloding install the cd follow the instructions on the screen and click next
    7)restart when the printer is loded.connect the wires and cords properly.
    Nov 29, 2008 | HP LaserJet 5p Printer
    Why is my printer showing a idle status and not printing?
    I believe the printer is connected via USB.
    Check in device manager if the LJ 1020 printer is listed.
    If yes, go to the driver properties > ports tab and Select the appropriate port for the printer
    Alternatively, uninstall the full software and reinstall it again from
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=439320&
    - Nikhil
    Nov 18, 2008 | HP LaserJet 1020 Printer
    Network printing
    If you can see it, it is set up right, however, the configuration might be wrong. Go to printer properties in the control panel. Open up the ports tab, select configure port. You will see that it is probably set: protocol:Raw, port:9100. Sometimes the port is 10001. Otherwise, set it to LPR, and put LP1 for the queue Name. That should do it.
    Feb 20, 2008 | Ricoh Aficio 1018D All-In-One Laser...
    Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
    HP LP1020
    ok, y solved linking the printer with the application provided with the dpr, PS-link, its added a new port and printer and works fine since. hope helpfull
    Sep 12, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
    D-Link DP-300U (DHDP300U) Print Server Logo
    235 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Ekse
    Mike
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
