FixYa.com
Tags:
Sony KP-51HW40 51 in. Rear Projection Television
Sony KP-51HW40 - not capable of displaying native... (by 2 users)
By Rogers - usenet poster
This unit is not capable of displaying a native 720p format signal.
When the 720p format signal is received, it is converted into a 480p
format signal.
Has anyone experienced this...and if so how much of the difference is
really noticeable to the naked eye.  My understanding is that 480p is
like watching a DVD...which to me is not such a bad thing.  I do
understand the HD is suppose to be much better than watching DVD.  I
guess what I'm asking...is this the end of the world?  I will be
getting my HD signal from Time Warner cable...does anyone know if
their signal is transmitted in 1080i, 720p, 480p,or 480i??   If it's
1080i...I understand that it's pretty darn good.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Ruth Montero, posted on Jun 03, 2008
POR FAVOR NECESITO QUE ME ENVIEN UN MANUAL DE UN RETRO PROYECTOR SONY DE 52" EN ESPAñOL A MI EMAIL rimonterog@yahoo.com
Gracias,
Ruth
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My understanding is that the Sony monitors convert anything above 480p to
1080i using the DRC (Digital Reality Creation) engine.  That is 720p is
converted to 1080i and 480i is converted either to 960i or 480p ore even
540p using other algorithms.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
Your understanding is incorrect.  Sony KP-51HW40 manual, page 39:
"When a 720p format signal is received, it is converted into a 480p
format signal"
And where did you pull 540p from????
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----==  Over 80,000 Newsgroups - 16 Different Servers! =-----
Solution #3
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
The HD signal from TWC's Scientific Atlanta cable boxes
(2000HD or 3100HD) are 1080i over either YPrPb component
(both boxes) or RGBHV (option for 2000HD only).  The SD and
NTSC signals are 480 via S-Video, Composite, or Coax. If the
programming was originally 720p it will be upconverted at
TWC's headend into 1080i and sent down to you that way.
You must feed that model 1080i; not 720p. Its specs out like
most HD displays; it has no internal tuner and only displays
HD at 1080i. That is done to keep costs down; few can do
720p too. This not a problem as virtually all STBs will
convert any 720p (like ABC uses) to 1080i.  There may be
slight differences seen by some users but generally it is
considered not something to worry about.
Bruce
Solution #4
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
I think it means that the display should be capable of receiving via a 480i,
480p, 720p and 1080i signal and it is up to the manufacturer to decide to
change it to 1080i or 720p......  both are considered to be HD.   There is
no display on the market that displays all formats natively....  either 720p
or 1080i    This is mostly due to cost and technology..... to expensive to
make a set that displays all formats and the technology does not allow the
mapping of pixel sizes appropriately.... this may change with DLP and LCOS
sets, etc.   The funny thing is that manufacturers are putting HD ready or
HDTV on the monitors even though everything is converted to 480p or 1080i.
Solution #5
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
For a monitor to be called HD, it has to be able to handle all 18 of the
standards.  That said, most all of the current crop of CRT based (direct
view and RPTV) TV's do NOT support 720P natively.  Fixed pixel devices (DLP,
LCD etc.) typically support 720P natively as they are progressive devices by
nature.  I believe Phillips used to have a RPTV that was 720Pnatively.
Solution #6
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
I know that sets with DRC chip do this.
Can you Help with these Projection Televisions problems?
Sony KP-51HW40 51 in. Rear Projection...
My Sony KP-51HW40 isnt staying...
My TV just wont work like it... Answer This...
Power
Originally the tv started... Answer This...
sony KP-51HW40 51in
when i turn it on picture seems... Answer This...
one third of the screen is...
the left side one third of the... Answer This...
Getting blue picture from...
My Sony KP-51HW40 51" rear... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
