to clear document jam: 1 Open the front panel. 2 Carefully remove the jammed document. 3 Close the front panel firmly until it clicks into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press Cancel appears in the message.
if the paper is jammed in the printing area 1 Remove the jammed paper by pulling it out smoothly in the direction of the arrow as shown. If the paper tears when it is being removed check to ensure that no small pieces have been left inside the machine. 2 Press Cancel. 3 If this was a fax, reprint the fax. For more information, see reprinting faxes on page 29.
if the paper is jammed in the paper feed area 1 Remove the jammed paper as shown. If the paper tears when it is being removed check to ensure that no small pieces have been left inside the machine. 2 Reload new paper with the print side facing toward you. 3 Press Cancel when finished.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
It has messages or faxes in memory, and is waiting for the right conditions to print. You may need to add paper, replace the toner cartridge, or clear a paper jam so that the printer can work.
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
I need to know if it still reads "paper jam?" If so, there must either be some piece of paper that is triggering the paper sensor, or the paper sensor actuator has become misaligned.
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
