Question about Hitachi 43FDX15B 43" Rear Projection Television
43FDX15B has blue lines on the screen somtimes
My 43FDX15B has sparking blue horizontal lines on the screen sometimes. When I touch the back of the TV especially TV antenna input area, the screen becomes clean for a while and starts to have sparking blue lines again. Please help me. Thanks.
  • 2,712 Answers
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white picture. Now adjust each CRT screen so that you end up with a true black & white picture. Then adjust each focus control to get a sharp picture, and adjust each CRT focus one at a time for clarity by covering the other two up. Then go back into picture adjust and turn color half way up, you should see a better picture.
If you cannot get the blue & green to even out to a black & white screen you have other problems such as faulty CRT card on back of tube or it could even be that the video IC is faulty. If this is the case, then you may have to get a competent local technician to check the TV and get the necessary parts replaced. It could set you back between $200-$400, depending upon how many components need replacing.
You can also try a hard reset..Unplug all cables, including power from the back of TV. Wait for 4 hrs and reconnect them. Try and see if it works now.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Posted on Apr 26, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
Older big screen hitachi w/pip tube tv and has blue lines across the screen turn off on it own sometimes.
It could be time to retire the TV.
The blue almost horizontal lines are probably a fault in the flyback blanking and the fact that it will turn itself off is likely due to a poor solder joint on a circuit board inside.
Jun 26, 2016 | Hitachi Televison & Video
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
Help me to fix the TV
Try to inspect for a loosed connection in the printed circuit board especially in the horizontal circuit. This includes the ic for horizontal oscillator, transistor for horizontal driver, horizontal output transistor and the high voltage section which includes the flyback. Pls. observe safety when dealing with these ciruits coz it deals with high voltage! Good luck!!
Apr 22, 2008 | RCA 27F650T 27" TV
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Jagged horizontal blue lines everywhere
convergance amp ic bad
Mar 10, 2007 | Mitsubishi VS-45609 TV
Hitachi 43FDX15B 43" Rear Projection Television Logo
76 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
