Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Not cleaning as good as it used to
I cleaned the filter and the vaume does not clean the carpet as it used to
    President:
  • 1,673 Answers
This vac. has alot of removeable covers, make sure that none has a clog and also that they are reinstalled correctly leaving no gaps. Does air blow thru the filter? Even after cleaning, if air can't pass thru, then they will restrict suction. Also is the brush roll turning, if not, then it would seem like there is not enough suction.
Posted on Jan 14, 2008
6ya staff
SOURCE:
My carpet cleaner wont stop leaking water after cleaning and i need keep vacumning up excess water
The unit works on suction and can develop a syphon if the filters get clogged. There's 2 filters that you should be cleaning after each use. One filter is located under the Flow Inidicator: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. Reinstall in reverese order. If that didn't help you may want to call Bissell Consumer Care at 1-800-237-7691 Hope that helps.
Dec 24, 2014 | Bissell ReadyClean DirtLifter Carpet...
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
How to clean your carpet?
Clean the carpet with regular vacuum, baking soda or vinegar is the best cleaning option to remove the stain or dirt over the carpet and also helpful to make long life of carpet with cleaning.
_________________________
crawl space vapor barrier seal
Jun 28, 2012 | Vacuums
Dyson animal vacuum 07 --5 years old no suction
the only way to fix the problem is to clean out the motor filter that's inside, the filter is around the motor and they don't do replacements for this part, as its not accessible by normal use, you need to remove all the case screws and disassemble the hole case, this site may help you https://manchestervacs.co.uk/DysonForum/index.php?topic=76.0
Jan 08, 2018 | Dyson DC05 Cylinder Bagless Canister...
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Changing from carpet cleaning to hard floor cleaniang
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=540075
Changing from carpet cleaning to hard floor...
Posted by Charlottek on Apr 23, 2008
Bissell 9500 ProHeat 2X Clean Shot Upright
How do you change machine from carpet cleaning to hard floor cleaning?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The Bissell 9500 ProHeat 2X Clean Shot Upright are mainly designed to do mostly carpet, you can use it for bare floors, but for good wood floors I would use less water and pickup the water ASAP because you don’t want the good wood floor to warp - linoleum floors are fine but be careful with wood floors, and remember that the Bissell 9500 ProHeat 2X Clean Shot Uprights
Clean on the pull back, you squeeze the trigger, dispense water, the machine will use the scrubbing brushes to clean and the vacuum will pickup the water all in one smooth motion.
For further information please feel free to contact your local vacuum cleaner dealer in the area or the yellow pages or contact the Bissell Factory @ the information listed below:
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
80 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Gerry Harvey
Gerry Harvey
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
