Question about Motorola Mobility H700 Wireless Headset
Bluetooth h700 my bluetooth h700 has water damage how do i fix it please
    Genius:
  • 1,003 Answers
If this headset has been exposed to water its probably cheaper to get a new one they are thirty bucks at www.n1wireless.com
Posted on Jan 14, 2008
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
Water on the bluetooth
Typically Water damage means the end of an electronic device. Leave it off for a couple of days and then try it again, but there is a good chance that it is dead.
Jun 07, 2010 | Motorola Mobility H700 Wireless Headset
Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
Jul 24, 2009 | Motorola Mobility H700 Wireless Headset
Lost software cd for h700
The computer should be able to look for the software automaticly in reguards to the bluetooth device. however, here are the steps. 1. turn on the bluetooth on the computer. 2. set the h700 into pair mode. 3. set the computer to find any devices. 4. password for the device is usually "0000" 5. connected.
Hope this helps ya
Apr 14, 2009 | Motorola Mobility H700 Wireless Headset
Pairing my bluetooth
the solution was to replace my phone.i found out that it had been damaged by a previous owner.
Mar 21, 2009 | Motorola Mobility H700 Wireless Headset
Motorola h700 pass key
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
Problems w/H700 bluetooth
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
Jun 20, 2008 | Motorola Mobility H700 Wireless Headset
H700
go to www.n1wireless.com get another one of these for about 30 bucks.
if yours has water damge it probably toast water always seems to ruin electronics
Jan 14, 2008 | Motorola Mobility H700 Wireless Headset
Problem with Motorola H700 Bluetooth
rhondarenee: If you're using a Motorola RAZR V3, the problem is the cell phone. Also check the volume buttons on H700 that sometimes it goes the volume all the way down. It is a common unnoticed situation. SithPitt
Jul 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
87 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
