Question about Acer Aspire 5100 Notebook
I have a fujitsu c series life book labtop. screen really dark
Hello, sorry for the question.
I have a labtop that the screen goes really black and you can hardly see the info on the screen.
It happend just like that, one day working the next day when turned on it does not.
I know the battery is bad it only holds about 30 minutes of energy but I always have the lab top plugged in.
Now is the screen broken?
Can I get the screen back?
I also have a hook up on back for a another monitor I plug into with a monitor but do not know how to get that to work .
Thanks for any help in advance.
Rich
  • 1 more comment
  • rrakness Jan 20, 2008
    Thanks for the help but that did not do the trick.
    I plugged in the monitor and hooked up and turned on the labtop
    The monitor said:
    dpms
    please check signal
    Nothing came on.
    I even tried another monitor and that would not come on either.
    I heard something about pressing fn- f5 or f7 and tried those things and did not see anything .
    after rechecking the battery it only holds about a few minutes of power.
    Thanks for any help
    I messed with a few more of the f1 and f2 etc buttona dn got it to work..thanks
  • rrakness Jan 21, 2008
    Thought it was fixed but when I turn on the monitor the xp comes on and then logs on then it says out of frequance and goes blank
I have this problem myself at the mo with a fujitsu siemens amilo laptop, the brightness up is fn + F8 on my laptop though this has only helped slightly. I have to have my desk lamp shining on the screen to be able to see anything. I think it may be a problem with fujitsu LCD screens. If I find a solution will let you know.
Posted on Aug 18, 2008
  • Anonymous Sep 18, 2008
    I have now got my laptop fixed, it was the inverter for the screen. will cost from £50+ dependant upon your laptop.
Buy a new lap top
Posted on Mar 15, 2008
    Champion:
  • 238 Answers
Hi, u have to plug in the external monitor in a switched off mode, when powered on, the system will automatically detect the monitor and u will see the display, if there is no display even on the external monitor then u will have to check the laptop.. let me know
Posted on Jan 14, 2008
6ya staff
SOURCE:
Fujitsu siemens Life book 2210C modem driver
Hello try the fujitsu homepage here:
http://support.ts.fujitsu.com/Download/Index.asp
And select the pc model and number, or enter the serial number.
Good luck
Feb 11, 2013 | Fujitsu Siemens LIFEBOOK C2240 PC Notebook
My labtop cannot start up, lock light on front panel light is on, hard disk is not flashing, screen is black, can you please help?
my labtop will start up the front panel will light and i see will there welcome to Fujitsu
and the screen will be black it will not display . what cause that i want know ...
Dec 21, 2010 | ASUS N61JQ-B2 16 Notebook, Intel Core...
Hello I have a fujitsu labtop, and it boots up
reinstall the vga drivers again
uninstall from the device manager
reboot and it will auto reinstall itself
hope this helps
Rate me please
MISTERDJ
Apr 10, 2010 | Fujitsu Computers & Internet
Fujitsu C2310 dark screen
buy a new battery for the laptop...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 23, 2009 | Fujitsu Siemens LIFEBOOK C2310 PC Notebook
Hello dear sir i have an old samsung labtop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 02, 2009 | Computers & Internet
When booting screen goes on for a second and blank after that
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 11, 2009 | Fujitsu Computers & Internet
My laptop displays very dark
Unfortunately, (Isay that a lot on this site), your lcd screen is backlit with tiny flourescent lights, sounds like these have been broken not much to do except talk to a local tech and hope that he has an lcd screen to swap or steal parts from.
Sorry my prognosis is not better...
Ed Meyer
Owner
AACS
www.alwaysaffordablesolutions.com
May 22, 2009 | Fujitsu LifeBook® S2210 PC Notebook
Power goes off when booting ...
Hi if you had not used your notebook for sometime and kept it without charging the batt., then charge the batt fully probably for 12 or 14 hours and then switch it on .
May 24, 2008 | Fujitsu Siemens Lifebook C2230 Notebook
Fujitsu c series labtop screen goes blank, the hooked up to a monitor, starts to work then says out of frequence and goes blank
The video resolution and/or frequency that's set in windows is not supported by the monitor you have plugged in. Restart the PC in VGA mode (hit F8 after the BIOS messages but before any Windows messages) and change the video settings to something basic, such as 800 x 600 @ 60 Hz. Then restart the machine normally.
Jan 21, 2008 | Fujitsu LifeBook C6555 Notebook
Acer Aspire 5100 Notebook Logo
313 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
