Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Water and ice dispensing out of control
The ice and water (depending upon where we have it set) is shooting out of the dispenser by itself.  We finally got it to stop by pushing the control lock button but if we unlock it, it starts again.
  • 3 more comments
  • dkweddle Jan 14, 2008
    single
  • Anonymous Mar 26, 2008
    door dispensar shooting out water or ice out of control by itself.
  • Anonymous Apr 16, 2008
    Also had the same problem - had to have whole panel replaced
  • dkweddle May 21, 2008
    We ended up having to have the panel replaced as well as a water valve up in the hood.  It cost about 300 dollars.  Now the freezer won't stay cold.
  • robert samples May 11, 2010
    does it have a single or double paddle on the disp
    President:
  • 1,314 Answers
Ok that paddle acuates a micro switch up in the door people have a habit of getting their drinks then gitting their ice this splashes sticky liquid on the switche and makes it stick the easist thing to try first is to get a can of wd 40 with the tube on it and spray the swich and work the paddle back and forth if that dont work then we will have to replace the switch so get back with me
Posted on Jan 14, 2008
6ya staff
SOURCE:
Firgidare ice dispenser dispensing ice without the switch bring touched. Is this a control board issue or something else?
try taking you ice tray and dispenser out and cleaning them of any frozen ice. sometimes the dispenser system kinda jambs and then stuck ice come out as it melts slightly and frees itself from the dispenser shoot and mechanism good luck
Mar 19, 2015 | Refrigerators
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Ice maker works but no water out of water dispenser?
Hi
You have not supplied the make or model of your fridge and so I can only offer a generic response.
Most ice-makers, chilled water dispensers are reliant upon a water stop valve that make a distinctive click when operated.
Does it click when you dispense water?
If not, then assuming the ice dispenser works (indicating the activate button is working), then the water valve has possibly failed (or less likely the wiring somewhere in between).
Dec 15, 2013 | Refrigerators
I have a whirlpool model ED25PWXBN00 refrig and the ice maker is making ice but the part that holds and dispenses the ice has broken and no longer dispenses ice. what part do i need?
That depends if the ice maker continues to fill with water or just sits there with the ice slots empty. Sometimes it is the dual water control valve=> 4318046 Water Control Valve
and sometimes the ice maker itself. Does not hurt to have an extra part of each if you are a ice user like myself. If ice slots are empty fill with tap water and allow to freeze. If the ice drops and slots do not refill with water then replace the dual water control valve. 4317943 Ice Maker Assembly.
Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser will not stop
Your water control valve is stuck open because of defective microswitch in door dispenser. (Behind where you press your glass) or the water control valve that opens when dispenser is pressed is stuck open due to particals of debris caught in the dual water control valve. For example the=> PSS26MGPACC Item 72 in photo or in dual water control valve itself=> Dual Water control Valve
Sea Breeze
All answers does depend on your model number, Click Model Locator here=> GE Model Number Locator Side by Side
Top Freezer
Bottom Freezer
Please let me know if helpful or if you have other questions, Thanks, Sea Breeze
Feb 14, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
No water to ice maker. I want to check the water solenoid to see if it is getting power. I don't have a diagram. is it a 120 volt solenoid? and when does it get the signal to open and allow water into the...
The water control valve gets its signal from the ice maker itself. Then begins the cycle of about six different functions until the ice ejector forks go to the position you see most (home) Then it tells the water control valve to open for about seven (7.5) seconds. You may test the true voltage from the female connection with a OHM meter set to AC voltage. Just have someone press the dispense water control. You can also check each sides coil windings for resistance or OHM's and they should be the same or very close to the same. Use care in the area of the coils and make sure the wires are not wet. One of the two wires for each side may be active even without pressing dispense or having ice maker call for water. Another thing I noticed is that you have two sets of water control valves. The problem is about as much with the Primary Water Control
Valve Part Numbers=> 12544002 and Secondary Water Control Valve => 12002193
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
Dec 14, 2010 | Amana DRS2660B Side by Side Refrigerator
Does not make ice, does not dispense water. Can
Sounds like the motor that controls the water flow is either broken or defective. Or the water valve is turned off.
Feb 03, 2010 | Refrigerators
GE Refrigerator
first, let us explore the problem with dispenser flap. open the freezer and look into the ice discharge chute. there may be an accumilation of ice impeding the proper operation of the flap. next, you have indicated the light socket is broken. is it just the bulb or the socket itself? if you wish to remove the ice/water panel, first unplug the unit,. then you may be able to unsnap the drip tray where one would sit their water glass. if you are successful in doing this then the panel can be removed with a star driver but it depends upon the fasteners used. Always keep in mind to disconnect power before working on unit. I hope this was helpful.
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
189 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
