Question about Avanti DG241BS Stainless Steel Gas Kitchen Range
Problem with the ignition.
I have problem with the ignation of the oven. Avanti stainless steel small stone/range. i can start the fire with the lighter but not with the ignotor.
SOURCE: Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Posted on May 05, 2009
0 characters
1 Points
Oven no spark
Does the igniter glow white hot and try to lite? If not, replace the igniter, here is the part to order.
Keep me posted!
Dec 27, 2013 | Thermador Pro Grand PRG366EG (Gas)...
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
My bottom oven is not heating up past 270. Do I need to replace the ignitor?
Yes exactly if it takes forever to ignite or the flame is small the ignitor needs replacing
Aug 09, 2011 | Maytag Gemini 30" Self-Cleaning...
Where can i buy the piece that turns the oven on and off...the knob thing?
You will have to attend a specialist spare parts store which supplies appliance parts. You wont find it in a hardware store.
Feb 08, 2011 | Avanti DER241BS Stainless Steel Electric...
I have a 30" stainless steel cand black gas range with electronic oven control and self ignited burners. For some reason the burners won't self ignite they don't even spark but the gas is comin out. What...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 21, 2010 | Frigidaire FGF337EC Stainless Steel Gas...
The dial on my Avanti 24" oven is hard to determine which way to turn. When I hear the clicking sound, as the burners do, next I hear the lighting, whoom. Shall I start it at a low temp and then in a few...
It sounds like you are having an excesive buildup of gas pre-ignition. You should hear no "Whooom" sound.
The ignition assemble likely needs to be cleaned of rust, dirt, grease etc. That is the typical cause if improper ignition, gas buildup pre-ignition etc.
The problem of not staying lit is caused by either the flame sensor not sensing flame, (which may need to be cleaned or replaced.) or that the flame is simply being blown out by the air movement as a result of the sudden combustion of excessive gas build up.
So, to summarize, the ignition and burner assemblies need to be cleaned, and the flame sensor may need to be replaced.
Oct 12, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
Oven will not stay lit
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jan 03, 2009 | Avanti DG241BS Stainless Steel Gas Kitchen...
Lighting the oven
I have similar problems with several 20-inch Avanti ranges. Solution(s); Get a new range, different brand. Cool the range between lightings.
Dec 21, 2006 | Avanti DG241BS Stainless Steel Gas Kitchen...
Avanti DG241BS Stainless Steel Gas Kitchen Range Logo
Top Avanti Kitchen Ranges Experts
Shawn DuRee
Lawrence Oravetz
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
