Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral Ice maker water filter, which one?
Hi I have an Admiral HMG 62163 with an ice maker and want to put in a water filter how do I do that and which water filter do I use?
Thanks,
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Posted on Dec 06, 2010
How do i remove an ice maker from an admiral hmg 62184
Most have a multi-connector electrical plug and a couple of screws that the ice maker hangs on. Disconnect the connector (most squeeze somewhere) and then loosen the screws. You may have to stick your head inside to see them. The water just 'falls' into a trough and thence to the chiller.
Jul 23, 2014 | Refrigerators
Ice maker stoped
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker won't make ice after replacing water filter -plugged
I've had the discolored water before when replacing the filter. It normally means that there was gunk in the water line.
Do you still hear the ice maker trying to draw water in?
If not, the water pump might be burnt out.
If so, see below.
The water lines that feed the dispencer and the ice maker split after a certain point.
It's possible that the line that feeds the ice maker might be clogged. You should be able to get to it by removing a few screws and pulling off the back panel of the fridge. Then you can check them out and remove the clog.
Comment on the post if more helps is needed.
Jan 19, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Icemaker in Admiral side by side refrigerator/freezer stopped working
see if you can bleed the air trapped in the water line to the ice maker. if air is trapped, water would not be flowing and it would take only a few seconds for the solenoid to be open to let water flow.
see if you can hot wire the solenoid to let water and air out of the tube long enough to bleed the air and hopefully, the ice maker would work continuously.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Apr 12, 2008 | Refrigerators
Need a water filter for my ice maker
you can go to any appliances parts store and get an in line filter it in stalls in the incoming water line before it screws on the water valves comes with instructions if you get the kit
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
386 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
