FixYa.com
Tags:
Sony KP-57WS500 57 in. Rear Projection Television
Sony KP-57WS500 (by 2 users)
By kioner - usenet poster
I just bought a 57 inch sony projection TV about 2 months ago. The Picture
was great initially but now it is almost green. i have done adjustments but
no avail. The white background is green. Does anyone have an idea what i can
do to get rid of the green saturation.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 07, 2008
Tv has green and purple throughout picture and it is not clear when you change volume the volume lines are arced.
Best Solution
posted on Aug 09, 2005
Thanks for Trying (70)
Horner
Horner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It's on warranty (I assume) so call a service tech and schedule a visit.
  Something is clearly out of whack.
Phil
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
If you just bought it 2 months ago, it should be under warranty.  I would
try the warranty bit myself, it might save you a few hundred.  As far as
calibrating a rear projection set yourself, forget it unless you have the
proper equipment and lots of experience.
Bill
Solution #3
posted on Jan 10, 2008
Not Rated (0)
ctf1800
Rank:Wiz Wiz
Rating: 85%, 3064 votes
Try the attached procedure. This has proven to be very effective. but done at your own risk
Enter the service mode by pressing Display, 5, Vol +, Power.
Press Menu and go to Setup. Select Image Revision and set to 1. Press Menu once to exit the menu screen.
Cycle thru the service mode using button 5 until you get to D-GM TG. Press number 1 on remote once. You should now be at the 1 POS CTL. Change data from 11->1.
Push the number 1 button on the remote 14 times until you are at 15 ENB POS. Change data from 5->23.
Push number 1 button on the remote 8 times until you are on item number 23 PRG POS. Change data from 0->2. Write the data to memory by pressing MUTE, ENTER.
Push number 2 on remote 6 times until you are at H POS SHIFT. Proceed with the following steps very carefully. 0 VAR POS-CTL=0. Press number 1 on remote. Change D-GM HP item 1 from 9->11. Write the data to memory by pressing MUTE, ENTER.
Press 4 on remote. Change to 0 VAR POS-CTL=1. Then press #1 on remote. D-GM HP ITEM #1. Change data from 9->11. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=2. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=3. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=4. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=5. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=6. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=7. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=8. Then press #1 on remote. D-GM HP ITEM #1. Change data from 5->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=9. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=10. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=11. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=12. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=13. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=14. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=15. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data.
Press #5 on remote 6 times back to catagory D-GM TG INV CTL. Press number 1 on remote once to the Catagory D-GM TG 1 POS CTL. Change the data value to find the best setting where no double images, ghosts nor merged colors appears. WRITE DATA.
Press #2 on the remote 11 times to the Option-E O Lamp Time. Note the current value and write it down. Add 2000 to the value (ex if 1356, than 1356+2000= 3356). Divide this number by 100 and write this value to the Option-E 11 P CTL SHT1. For our example above we would have 3356/100= 33.56. So we can round to 34.
Now add 50 to this number. In our example we would have 34+50=84. Write this value to the Option-E 12 P CTL SHT2. Make sure to write the data.
Select AUTO in the menu for the Image Revision setting and exit the menu screen. Confirm that the picture is fine.
Solution #4
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
There isn't anything you can do to fix it. It is a common problem with a
certain set of Sony TV's. Any consolation you aren't the only one with this
problem. The problems can include flickering in dark scenes, changes in hue
especially green. Depending on where you bought it and if there is any
extended warranty I would try there 1st. I bought mine at Circuit City and
was able to get them to exchange it for a new one even though I had had it
for 4 months. If you can't get it exchanged then go through the warranty
repair process. Definately contact SONY At Your Service customer support. Go
to some of the Sony Forums on the net and you will find a lot more info.
Hope this helps.... Mike... Here's some links...
http://www.agoraquest.com/foru m.php
http://www.hometheaterspot.com /htsthreads/ubbthreads.php?Cat =
Can you Help with these Projection Televisions problems?
Sony KP-57WS500 57 in. Rear Projection...
57" Sony HDTV KP-57WS500
I have a 57" Sony HDTV... Answer This...
kp-57ws500
Hi! I will be very happy if you... Answer This...
sony kp-57ws500 green screen...
when i turn te unit on the... Answer This...
bowed in picture
I have a toshiba color tv... Answer This...
pink line scrolling from bottom...
I have a 57 inch Sony rear... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
