Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Sony KP-57WV600 screen
I'm getting light green lines on my television--and the black screen seems to be going green...the volume indicator can't be seen any more.  How can I fix it?
  • 3 more comments
  • Barryola Jan 17, 2008
    This sounds like the right answer to my problem--
    What does a crt tube cost and can I install it myself?
  • Barryola Jan 22, 2008
    So I won't shock the shit out of myself by opening up and getting into the television? Mine is the KP-57VW600, not the one on the site you are referring me to.
  • Barryola Jan 23, 2008
    Thanks Rowdy, but it didn't work.  I couldn't figure out how to get the grille off the front of the kp-57wv600.  Took all the screws off I could find, but it still seemed "glued" on--and I didn't want to break it getting it off.  If anyone knows something, I'd love to know the secret to getting the grille off!
  • Barryola Jan 26, 2008
    Well, I was afraid to take the grille off myself, so I had the repair man come out.  $150.  But worth it, cause I saw how he did it (just like you said, but a little more "elbow grease" than I was putting into it).  He dialed out the green lines (just like you said) and then tapped the crt tube.  It made "flecks" on the screen and he said the tv would one day soon give me a flash of green and then it would be gone.  When it does, I'll probably do what you suggest above--send it away and get another.  Btw, he did all this while the tv was on.  No need for it to be off.  Thanks for your help.
  • cowboyD May 27, 2008
    got my picture back but its a little blurry what should i do?
Posted on Sep 09, 2008
    Problem Solver:
  • 9 Answers
It may need CRT or Just reduce the fly back transformer adjusted
Posted on Jan 17, 2008
  • Reza djedi
    Reza djedi Sep 09, 2008
    Fix for the green line---> Try Adjuesting the green CRT Screen ( A little turn CCW 1-2 mm ) control..
    Good Luck
    "I'm getting light green lines on my television--and the black screen seems to be going green...the volume indicator can't be seen any more. How can I fix it? "
    Problem Solver:
  • 7 Answers
I had the same problem except blue lines then all blue..I needed a blue crt I'm assuming you will need a green crt tube
Posted on Jan 15, 2008
  • 2 more comments
  • rowdyroddy Jan 17, 2008
    sony no longer sells crt tubes but there is a company called video display which sells tubes(supposedly brand new)_I have my doubts considering I must send crt tube and certain parts then they will send me NEW tube at $152.52...u.s.....they will tell approx what shipping will be....for me only $15 and I'm in for fixing... I myself am hoping to remove without repairman but have been told here there is high voltage contained withen set even after being unplugged(regrdless how long) so voltage must be nullified before removal of any I type I have a post hoping someone will have the answer for just that!!!.lol...chances are you may also have some minor issues as well ...I suggest getting repairman in once atleast to know for sure .....but beware of repairman ....mine wanted $300 for tube, $50 for convergence issue,3 hrs to fix for a $750 repair bill......I looked around and found tube cheaper as stated above which pissed him off so much he won't call back... that company # is 1-800-241-5005...ext 143...and they take c.o.d orders!
  • rowdyroddy Jan 22, 2008
    barryola .if your reading this ...You Owe i just saved you and everybody reading this .....hundreds and hundreds in$$$$$...........your fix as well as mine is as easy as a turn of a screwdriver....NO SHIT!!.........found this site ......go to this fix'es all sony rear projection tv's....crt tubes can be adjusted NEVER CHANGE YOUR TUBES...their not the problem....the voltage withen tube changes over time .. and a simple power surge can throw your colour out the problem was blue lines then solid blue screen then shuts off ,,,,, blinked 7 times ..followed simple instructions and voila my tv is all good again and a philips screwdriver is all I needed.....
    i too have kp-57wv600 and it is at that link...if you check this fix applies to all sony rear projection testimonial(comment) dated 12/26/07 by paul t(near bottom of page) explains how to remove our front panel ...and adjusting screw(s) is universal...I tried this last night and my tv is all for voltage ....adjust while tv is unplugged and all is took me alot longer than 5-10 mins. but easy to do ......i just used the link from earlier post to check myself and it's all there....just remember to adjust 1 notch at a time (left or right depends on your tv (i recomend doing at night or dark as possible)
  • rowdyroddy Jan 23, 2008
    ok barry. here we go....1st remove 5 screws each side behind speaker grill(10 screws in total).....facing tv pull bottom of front faceplate toward you (IT WILL NOT BREAK-4 snap clips must be dislodged) ....careful not to pull to far from tv as it has 3 wire harnesses plugged into front panel circuit board.....if panel hasn't completely come off yet.......push top part of panel in and slide downwards and it's you can see small panel containing the 4 screws .once removed all will be revealed as in the site link photos....DO ALL THIS AND ADJUSTMENT WHILE TV IS UNPLUGGED!!....i recomend putting small panel back in(not screwed in) after every adjustment and lean front panel up against tv before plugging back in to see how adjustment worked....let me know how that worked out for ya.
57wv600 blinks 7 times, no picture, or blue for few seconds
1. Remove the 5 screws from behind each speaker
2. Grasp bottom center of plastic panel and "pop" forward. Swing upward to remove.
3. Remove 4 screws from the wooden panel in center.
4. There is a "black box" in the very front of electronics. It will have torque paint on the 2 rows of 3 screws. top row is labeled "focus"
MY TV would go green before going black. Volume still worked.
5. I turned the center bottom screw (marked "green") appx. 1/8 to 1/4 turn COUNTER clockwise.
Plugged TV in and it works fine.
Oct 08, 2011 | Sony KP-57WV600 57" Rear Projection...
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair or have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
I have a sony kp-57wv600 and when I turn on the tv the screen is green for at least ten seconds and then shut down.
It sounds like you have a bad GREEN CRT.
I would not invest the amount of money to replace the CRT. It would require a Qualified Service Person to come out to your home and remove the GREEN CRT ASSEMBLY and send it to Sony so they can rebuild it. Too much time and money would be wasted. I estimate it would cost around 800.00.
I hope this helps,
Oct 28, 2009 | Sony KP-57WV600 57" Rear Projection...
Sony goes blue
you need a new Blue CRT you can get them at the following link.
Jan 15, 2009 | Sony KP-57WV600 57" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony kp-57wv600
hola al problema lo debes tener en los transistores de color que estan en en la plaqueta donde va el socalo debes tener alguno desoldado
Sep 24, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
Jun 22, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WV600
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Blue to Black screen on Sony KP-57WV600
i too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. never change your tube it is not the prob!!!!!!!....go to read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Dec 28, 2007 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
1,397 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
