Question about Sunbeam SMW777 Microwave Oven
Smb6500b will not heat but turntable trun
    Master:
  • 619 Answers
Hi , replace the fuse in line with magnetron
Posted on Jan 14, 2008
Microware trun table does trun
Try to turn the turntable coupling under the glass tray by hand it should be pretty hard. If not, you may have a broken coupling. Those are plastic with a D shaped hole in them. If it has cracked, or broken, the motor cannot turn it. So either a bad coupling or a bad motor.
Oct 09, 2017 | Microwave Ovens
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Sep 06, 2014 | Sharp R-1505 Microwave Oven
Turntable
Your turntable motor is most likely faulty at this point. Contact your manufacturer for a price quote on the part, then you're looking at around 1 hour labor.
Jul 23, 2012 | Frigidaire PLMV168 Microwave Oven
Turn table will not trun
The turntable motor is defective and needs to be replaced.
Mar 05, 2011 | GE Profile Spacemaker Over-the-Range...
Can you trun off the turntable
Hello paula.... there is no switch or other easy way to turn off the turntable. What you can do is simply remove the glass revolving tray and ring and use the microwave with the turntable removed. Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Sunbeam SMW777 Microwave Oven
Microwave won't heat. turntable works control
Hi! check the fuse that goes through the magnetron because i think it is no functioning.
Sep 10, 2009 | General Electric Microwave Oven
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sunbeam SMW777 Microwave Oven Logo
60 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
