Question about Logitech USB Desktop Consumer Microphone
I have a MAC MINI AND MY USB MIC IS NOT WORKING ON IT.
Please help, I can not get my mic to work on my MAC MINI.
Michelle
  • caraab3 Jul 04, 2008
    bought a rocketfish USB Micropphone today for my Mac Mini Not working.  went on skype and they couldn't hear me
  • Anonymous Apr 11, 2009
    when I plug it, it does not speak.
How do you get my computer on a mac??? also i can not get my mic to work on the mac mini? it is a logitech. any suggestions?
Posted on Jul 26, 2009
  • Logitech Master
  • 13,433 Answers
This product uses native driver support on a Mac. No Logitech Mac Software is available or required.
It should work instantly check your sound settings the mic might be on mute or your useing wrong input on your program.
Posted on Apr 28, 2008
  • mp1008 Oct 16, 2010
    The Logitech USB mic works very well with a Mac mini, whether an old one or a new one. Here is how to set it up:
    1) Plug the Logitech USB end to one of the Mac mini USB ports
    2) Go to System Preferences>Sound>Input and select the Logitech device for sound input, set the input and output levels to high, and make sure the mute box is not checked.
    If you are trying to use the Logitech with Skype:
    3) Open Skype Preferences>Audio. Set the audio input device to the Logitech device.
BM-700 studio mic not working
I've had many problems with macs and AUX Input before. For some reason, some macs don't accept audio input from AUX. There are some dongles you can get that turn AUX to USB, I used that for my Mac Mini and it worked perfectly. You can find some cheap adapters online, I highly recommend you look up iMic, that's what I used. 4_27_2014_4_22_44_pm.png
Jan 07, 2014 | Audio Players & Recorders
The nexxtech hd portal 720p installation disk comes up on my mac desktop but when i click on it, it goes in to a file and i can't seem to instal anything everything either has no default application...
I have the same unit and it works fine on my Mac Mini. All the stuff on the disk is for PCs, not Macs. You don't need to install any drivers for this webcam when using it with a Mac. Just plug it in and it will work. If you are using it on Skype, for example, you have to select "preferences" / "sound" and then change the "input" to USB. That will make the microphone work. You can adjust the mic input volume in your Mac "System Preferences" / "Sound." This is one of the few cameras out there with a mic that works through the USB, so don't give up on it too easily!
I get a very slow frame rate with this camera, but I've had the same problem with every other webcam I've plugged in!! Otherwise the quality is fine. If anyone knows why my frame rate is so slow, I would appreciate your ideas!
Jul 09, 2011 | Computers & Internet
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Internal microphone not working
In the system preferences there should be a tab for input and, if you don't already have a USB headset or other external mic, then the internal mic should already be selected. You should be able to see in real time what the mic is receiving by talking. There is an input level bar that fluctuates. If this does not show anything, then you probably do have a problem with your mic. do this first though before checking out skype.
Here's an example
Skype has a walkthrough for setting up Macs
Nov 14, 2008 | Apple iBook G4 Mac Notebook
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Mokrophone is not working
Found the problem... What Apple has is a line-in port...it requires a pre-amp to boost the signal of your mic. A PC likely has a mic-in port.
They're different ports...very similar but they accept different levels of input. Apple likely wants you to use their built-in mic for mic use and the line-in port for line-level audio sources.
Thsi appears to be our solution... Griffin iMic / USB Audio Interface
What a pain.
Oct 20, 2007 | Sennheiser BINAURAL HEADSET :unitsize...
Logitech USB Desktop Consumer Microphone Logo
1,852 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
