Question about KitchenAid KGRI801PBS Gas Kitchen Range
Oven does not turn off
I have just gotten a Kitchen Aid Gas Range from my brother in law. He says it works great except for one issue. The oven will not shut off unless you unplug it or flip the breaker. Any ideas? It is either a KGRA806, KGRK806 or KGSA906 model from 2004.
  • 2 more comments
  • cold cooker Apr 16, 2008
    My oven does'nt turn off, it heats at 450* we have to turn it off at the breaker. Also it was flashing fl tonight, its scary. We turn it off when not in the kitchen.
  • farfara Jul 26, 2008
    I have the same problem with KGSA906PSS01. What piece of sh.. As someone suggested the problem with central control unit. I can't locate this part when I look at the catalog, instead there is part number: 9761942 Control, Migration. Is this the same part. I have had so many problems with this unit and they start appearing right ofter the warranty expired.
  • bd_detwiler
    bd_detwiler Jan 01, 2013
    The issue is the power button, this power button is on the display board.. everything works except for one button then go to the source.
  • Maurice Hilarius
    Maurice Hilarius Oct 20, 2017
    For a temporary solution:
    Press the "Cook Duration" button, then the "1", then the "Start". After it shuts off in 1 minute open the door to clear the display.
I'm having the same problem with model KGRK806. There's asking for $221 for the control panel part and another $180 for labor.
** If you want to continue using don't unplug or flip the breaker. Instead set the cook duration for 1 minute and it will auto shut off.
Posted on Aug 24, 2010
  • 5,911 Answers
The Electronic Oven Control (EOC) is probably defective. I have experienced this problem before and it was directly associated to a shorted relay on the EOC board. The board is not serviceable and must be replaced. I will need an EXACT model number to be able to determine the correct part, however. The model number can be located somewhere around the oven door opening (usually along the bottom drawer), or along the back of the unit (behind the control panel). Since prices can vary widely between models it is important to have this information. Post back with your information and I can help you further.
Posted on Jan 14, 2008
  • Jeff Rockwell
    Jeff Rockwell Jan 17, 2008
    The control board (called a Central Control Unit, CCU) on your model runs about $97 and the part number is 1181828. You can find this part at repairclinic.com. The part will be shipped directly to you for small shipping fee. They use the same parts as most of your major appliance repair companies and charge much less. I have used their service several times and have never been disappointed. I hope you find the website informative and I hope I have been helpful to you.
Put hot water on it then take a sledge hammer hit it pee on it and poop on it for the finishing touch fart as much as you can on it
Posted on Mar 14, 2008
I have the same problem, Im thinking its the Control Unit. Any ideas?
Posted on Feb 29, 2012
Thanks for you help.
The model number is KGSA906PSS00
Posted on Jan 16, 2008
My kitchen aid YKERC607 oven, bake, broil does not work. oven top works however
If it is an electric range, it would be a control issue. If it is Gas, it could be ignitor or safety valve.
Mar 15, 2015 | Ovens Ovens
Kenmore oven about 8ys old. The top works fine. When i turn the oven on the glow from the pilot light is visble. then nothing except strong smell of gas. Help. thanks Michelle
The glowbar ignitor has gotten too weak to light the gas.
Replace the ignitor.
Unplug the range.
Turn off the gas ****.
Remove the oven racks.
Remove the bottom oven pan.
Remove the flame spreader grate.
Remove the ignitor and replace it.
Make sure the new ignitor is wired correctly.
Aug 09, 2010 | Kenmore Kitchen Ranges
Kitchenaid gas range keeps beeping intermittantly, oven turns on by itself and code F2:E1 keeps comiong up on pad. What is the problem
Hi
Thanks for using FixYa. Error F2-E1 in your Kitchen Aid range indicates shorted keypad. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 29, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Oven Fridgidaire Model FGF326ASF
You replaced the EOC? Thats what the issue is
May 12, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Oven will not lite or work
most likely the ignitor has gone out. it is a simple fix that you can perform yourself if you wish. the ignitor runs about $70. Joe
Nov 18, 2008 | KitchenAid KGSI901PBS Gas Kitchen Range
I have a GE Profile Gas/Electric Oven Range that has stop working
P7 means Shorted Matrix Key. Power down and power up control. If the fault condition reappears within 15 minute - replace control. I got this off a wiring diagram that was in an envelope attached to my range.
Nov 21, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
KitchenAid KGRI801PBS Gas Kitchen Range Logo
1,127 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
