Question about Microsoft Xbox 360 Halo 3 Special Edition Console
I have xbox 360 halo edition and it powers up by it self and disc tray opens and closes by it self
    New Friend:
  • 16 Answers
Buy a new one i had that problem
Posted on Nov 30, 2009
SOURCE:
GAMES GOT STUCK IN THE XBOX 360 HALO EDITION THE 3RD TIME i USED IT
It needs a new drive chassis, you will have broken the little plastic tabs that hold the tray level and straight! you can replace the drive but the new drive will need either the old logic board off the broken drive fitted to the new drive or the dvd key dumped off the old drive and flashed to the new one to make it work.
Dec 23, 2012 | Microsoft Xbox 360 Halo 3 Special Edition...
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My sons have a limited edition halo green xbox but it wont read discs just says open tray.I then bought one of a friend and thats not working i plug it into the tv but it comes up no signal.I have 2 bored...
Fastest way would be install drive from no signal xbox to the halo edition
reg xbox drives are swappable
there are about 6 torx screws on bottom and 1 on the hdd tray 2 on drive holder not a very difficult fix
Aug 03, 2010 | Microsoft Xbox 360 Console
Loose disc tray
well, when you opened the tray with a paperclip, it probably jacked up the reading system. The you pushed it in manually. This will totally ruin the system. Try contacting Microsoft.
Jan 16, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Wont read disc,instead says open tray
Try turning the xbox on and off. Try removing the power from the xbox and plugging it back in. Try other discs and see if it works. Try doing updates on your xbox360 and see if that fixes the problem. That fixed mine with Halo.
Aug 07, 2009 | Microsoft Xbox 360 Pro System Console
My Xbox 360 Halo 3 edition hardly reads any disc successfully!
This most likley a weak laser .
8 mw 633 nm laser diodes fail in stages
as they get weaker the cd ups voltage
to the laser diode till you get to full gain, affter that
it's time for a new laser .Good news
there cheap 30.00-40.00 and not too
hard to swap out yourself .
Rob
Jun 13, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
May 12, 2009 | Microsoft Xbox 360 Elite Console
My xbox 360 wont read any disc
Call 1-800-4MY-XBOX and they will solve your problem.
Feb 03, 2009 | Microsoft Xbox 360 Console
Open Tray
just like i tryed to tell the other person send it back to mirco softand see if that works
Apr 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Halo 3 Special Edition Console Logo
134 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
