Question about Sony SDM-S73/B Monitor
Sony sdm s73 screen black - green light flashing - no amber light
How did this happen - did change contrast and brightness - under 3 years old - can it be repaired - under warranty - can I do anything to fix????
  • 33 Answers
1. If under warranty, take it to the service center immdtly.
2. The display cable might be loose plug it up.
3. Your system might not be giving signal to the display unit. Is the system running, Listen for a beep when u turn on the system. If there is a beep the System Ok for display or the problem might lies in the Tower itself.
Posted on Jan 05, 2009
I have problems with colors on my SONY SDM S73 LCD. Many of lighter colors are not displayed at all. I tried to update a driver, chanfe resolution, nothing changed... I use WinXP SP3 with RAGE 128 PRO...
tlnwiayqydee, In terms of lcd monitor age, unit is VERY OLD. Cold cathode fluorescent lamps will need to be changed for new ones. Very hard to do for consumer/user!!! Best if you trade-in for new unit. Did you even look at the "date of manufacture" on back of unit? Look here for lamp information: and and and You will need to also visit YOUTUBE for video clips of units being repaired. 12fixlouie
Oct 15, 2010 | Sony StylePro SDM-S73/B 17" LCD Monitor
My sdm-hs73 moniter the power is on but screen is blank, what could be wrong
First check brightness and contrast settings.
If all good could either be your lcd back light has gone or the inverter. To check if its the black light shine a torch through the back of the screen to see if you can see a slight image on it, if you cant see anything the inverter board is faulty and to repair needs to be changed.
Jan 21, 2010 | Sony SDM-HS73P 17" LCD Monitor
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Black screen after 1/2 second power-up of Sony SDM-HS73
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Oct 01, 2007 | Sony SDM-HS73P 17" LCD Monitor
Sony Monitor ... SOMEONE HELP, please!
Thanks for your response. I actually sent my monitor out to guy that does LCD repairs for cheap. He changed out the video board and did repairs similar to yours but still couldn't get the monitor to work. After some more testing, he found that one of the chips that contained Sony's proprietary firmware had gone bad and said there really was no way to replace the chip. It definitely seems like we had the same problem, so I thought this information may help. I'm sorry that you paid so much for repairs that didn't solve the problem.
May 14, 2007 | Sony SDM-HS73P 17" LCD Monitor
WEGA 36" : Screen is low contrast and green
Sorry to say, it sounds like a bad picture tube, But could be also the capacitor that filters the screen voltage on the crt drivers. In all my years though, your complaint has been the picture tube. Good Luck.
Jan 02, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-S73/B Monitor Logo
140 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
