Configuring leviton router
Hi. I just reformatted a pc and cannot connect to the internet. I remember something about having to input the routers ip address somewhere. 2 questions, where do I get the ip address, and what do I do with it. I have a functioning pc that connects thru the router and works, can I find the address on that pc, or do I need to contact leviton. Thank You, Paul
    Novelist:
  • 139 Answers
You can get the router's IP address from the functioning PC. Go to the command prompt by clicking on Start / Run ...and then enter "cmd" in the text area and click "OK". In the black window that pops up...type the command "ipconfig". The computer will list it's IP address, subnet mask and default gateway. The default gateway is the router's IP address.
To enter the Default gateway (router) address in the PC that isn't working...click on Start / Control Panel / Network Connections / Local Area Connection / Properties. In the "Local Area Connection Properties" window....scroll down and click on Internet Protocol (TCP/IP) to highlight it. Now click on the properties button.
In the Internet Protocol Properties Window....click on Use the Following IP address:...now you can enter the IP address for the computer to use, the subnet mask, and the default gateway. The default gateway and subnet mask are the same as the working PC. Hopefully you already know what the IP address for this computer is supposed to be....it must be unique on this section of the network. To function properly, this computer also needs to know what DNS server(s) to use. You can enter the DNS server address at the bottom of this screen.
If you don't know the DNS server addresses, you can look them up on the other machine also. Use the command prompt as described above and enter the command: "ipconfig /all" Look for the DNS server addresses in the command output.
Posted on Jan 14, 2008
Trying to connect ethernet cable to router but the pc still wont get any internet access. does something have to be configured or should it work automatically?-jose
It should get an IP address automatically.
Is the router configured for internet ?
Is there a device thats already connected to the internet with this router ?
Feb 17, 2015 | Belkin Computers & Internet
Tip
Internet connection not responding.....
Configuration of router is a big issue for internet computer networks.Problem:"http://192.168.2.1/ " is your ip address of your router. then the browser cannot allocate the specified address it's because this is not the exact ip address of your hardware. but there is an alternative way to get into the router and if you don't know the ip address (you can type in your URL bar http://routerlogin.com).1. NOTE! you should have to inputs the username and the password of your router, so that you can enter in your router configuration to change some of the settings.2. NOTE! miss configuration of router can be a big destruction of your internet connection. cause any type of browser you've installed in your system unit will be capable of any type of internet connection you've avail. 3. Tips: The problem is how you'll configure your routers.4. Default address: http://routerlogin.comGod Speed.
on Apr 11, 2010 | Computers & Internet
How can i input a security wep key
First you have to connected to it. You can do it wireless if you already configure your ssid and key or directly using a Lan cable. Some routers connect you directly using the CD ROM provide with it or using your internet browser but you need the IP address of the router that normally is show in the manual or in the same router. After you connect to the router you should look for the security configuration and configure your security web key.
Something like this: gabytek_0.gif
Mar 03, 2011 | Acer D-Link 2.4GHz Wireless Router 802.11b...
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
A client of mine has a Leviton 4 port Internet gateway. It's serving up DHCP to four connected computers. It's uplink is connected to a wireless Linksys router, which is, in turn, connected to a cable...
If you don't have physical access to the equipment, the shortest and easiest way to configure your leviton gateway would be to connect the linksys router to one of the numbered ports rather than the WAN/uplink port. That would bypass the DHCP server of leviton, however, you will have to do away with one of the PCs connected to leviton.
Please contact me for further clarification, if needed.
regards
Sandeep
Nov 25, 2009 | Leviton 10/100 Base-T Internet Gateway...
Cant connect to internet
Configuring router for Cable Internet (LINKSYS)
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Configuration Steps:
Step 1
Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' for password and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection Type to 'Automatic Configuration (DHCP)' option. Under Setup, click on MAC Address Clone tab. Enable it and click on "Clone My PC's MAC". Do this from the computer which the cable modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router.
Step 4
Click on SAVE SETTINGS and then on REBOOT THE DEVICE including the cable modem to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.1. You can do this on your router under Setup > Basic Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Sep 02, 2009 | Linksys Wireless-G WRT54GS Router...
My computer can see my router but can't get past my modem
1. delete all the saved networks from your computer
2. Make sure that firewall id disabled in computer
3. Tried to set your wireless as unsecured network and try to connect
4. Uninstall/Reinstall wireless adaptor and tried.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Trying to program my zonet zsr4154we with comcast modem cannot figure it out tried the sequence in the manual is there something else i must do also
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Configuring router for Cable Internet
Configuration steps:
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' for both.
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Setup'.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Log in to the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
Jul 24, 2009 | Computers & Internet
Unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
May 22, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Computers & Internet Logo
727 people viewed this question
Alun Cox
David Payne
David Payne
