posted by suzeee on Jan 14, 2008
power on pc, blank screen, green light flashing every 4 seconds, no amber light -
Comment by suzeee, posted on Jan 14, 2008
hep pleeeeeze
Best Solution
posted on Mar 17, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
It is not a computer issue. It is a power issue with the monitor. A tiny capaciator needs to replaced which requires soldering.... better just buy a new monitor if not under warranty
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 30, 2008
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Suggest a new solution for this problem
Post a New problem for Sony SDM-S73/B Monitor
Email this problem
Email this problem
Can you Help with these Monitors problems?
Sony SDM-S73/B (Black) Monitor
sony sdm s73 screen black -...
how did this happen - did... Answer This...
Repair Service
Find Monitor Repairman Near You:
