Question about Bosch SHU9922UC Built-in Dishwasher
SHU 9922 UC Top wash arm came off
The top washer arm came off of the back of the unit. How does it go back on? Is there a clip or something or what? I try to place it back on, but it just falls down.
We've just had the same problem, after a little frustration trying to get it to fix on to the back wall of the washer, we realised that it fixes onto the underside of the actual tray. When you pull the tray out, the arm comes with it, and then when you push it in, it engages with the holes.
Easy when you know how!!
Posted on Mar 23, 2008
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
I havde a top load washer . sometimes it doesnt start the wash cycle because its not recognizing that the top is closed. swe have to press on it most of the time for it to start .. but someetimes it stilll...
The lid switch is mounted to the top on the right hand side. First unplug unit remove the control panel one screw in each back of each end panel ,remove main retaining clips and pivot entire washer housing to gain access to internal parts..Also check hinge screws (2 small phillips head) on each side of lid ..the arm on the right side actuates the lid switch if loose could cause intermittent operation
Nov 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Wash water won't drain, machine stops
Unit will not run till most of the water is gone so the pump probably has something it it . Remove front panel(two screws in front at bottom ) lift top by depressing clips in seam between top and front panel lean back. Push down on front panel and remove . You will see pump
Nov 18, 2010 | Frigidaire FWS833A Top Load Washer
The spray arm, above the top rack, keeps unscrewing during the wash cycle. Just the arm comes off leaving a round plastic part attached to the top. This can be unscrewed and inside is a white 'washer'. The...
Could the arm be mounted upside down and rotating the wrong way? Just an idea... Some of these can fit either way and the retainer will fit either side of the arm.
Jun 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
MTW5870TW matag washer
Putty knife front of control panelbetween top of washer and control console (plastic) metal clips need pushed in twards back of unit top will hinge back they may spring off so watch wear they fly
Apr 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Top arm on my Maytag MDB5600AWW keeps falling off
Sounds like the retainer clip for top arm is defective. Replace the following parts:
1: 99002676 Washer Arm
2: 99002753 Top Washer Arm Retainer
To replace unclip top manifold from rear top clip on back wall then pull down on top retainer clip and remove arm, replace in reverse of these instructions.
Part can be ordered off net or thru any appliance parts house.
Nov 12, 2009 | Dishwashers
UC code on my Maytag Neptune Washer FAV6800WW
HI. this uc code represents a no spin state of the unit. this is caused by a faulty Motor control assembly. you will need to replace the Motor control assembly. this will fix this issue and, restore the normal actions of the unit.
This Motor control assembly will cost about $219.00.
Jun 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Bosch SHU9922UC Built-in Dishwasher Logo
97 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
