Question about Supersonic FC2245 13 Color TV/DVD Combo Television
I need repair parts
The tv set fell off the shelf in my truck and the cable pulled the part that the ant. cable att. to out off the tv. i need a parts list and a place to buy them
    President:
  • 2,992 Answers
I get lots of parts from a company called MCM Electronics, and they offer a replacement connector. Here's a link:
http://www.mcmelectronics.com/product/215543&CAWELAID=220241622
This is an RCA part but can be used on nearly any TV where the connector has been ripped off. (Make sure to use a soldering gun when soldering the new connector to the metal shield in the TV. The small iron you would use for other connections won't get enough heat into the connection.)
Posted on Dec 01, 2008
Toshiba lcd ant cable problems
1) you must repair the ant cable, see if the cable is open or break test with VOM, this can produce erratic problem.
2) you have the options to go to the repair shop TV for fix.
3) clean the contacts antenna TV, for dust, dirty or oxide.
4) repair any broken wires and solder.
5) of course you have the probably problem of some problem inside of TV example, TUNER, i-f,video detector, AGC. test it see the diagram
God bless you
Jul 12, 2012 | Toshiba CF36G40 36" TV
The calble is connected directly to the tv, not through the cable box & when i try to change the channel it says "no signal" at the bottom left corner. Olevia 32" model 532-b12
I assume from your question that you have a cable subscription and that you have the cable plugged into the ANT input via a co-ax cable. The ANT input is for an antenna for over-the air signals. The channel up/down change the internal tuner up/down. For example, if your cable is set to channel 3, it will pull in the cable on channel 3, but then try to pull in over-the-air if you hit channel-up to channel 4.
It seems you need some kind of converter box from your cable company in order to change the cable channels, and then that converter box would plug into either the ANT input (and leave the tuner on 3) or into one of the other inputs like Component, HDMI, SVideo etc.
Feb 13, 2011 | Syntax Olevia 532H 32 in. LCD HDTV
Samsung Ant 1 (Air) and Ant 2 (Cable)
no ant 1 is for dtv off air siginals ant 2 is for cable chann.
Feb 04, 2010 | Samsung DLP HL-P5663W 56" TV
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
I can't get the channel set up to work on the tv
check your coaxial cable antenna , try verify it using a standard tv if tv can get channel after you preset or auto tune meaning your ant. works. if not repair the ant. connection.
Jun 13, 2009 | Televison & Video
Broken Wii?
so it fell from the shelf huh! try to replace your A/V cable with a new one.maybe it was pulled of when the wii fells causing the wire inside to get cut.hope this one helps!
Dec 21, 2008 | Nintendo Wii Console
Cable connector pulled out of set
The box is called a tuner. You can not replace the "F" connector. It is to risky for a cunsumer. If you can solder well. Try and replace the tuner. If not take it to a repair center.
Nov 10, 2008 | Emerson Televison & Video
My sanyo tv will not show that the cable is there, even though it is hooked up. I tried adding/searching for channels but to no avail. What can I do to fix it?
HELLO. sounds like you need to go in the menu and find the setting for (air tv ant)/(cable tv ant), and reset.the setting to the cable ant setting. and see if that works "good luck"
Aug 02, 2008 | Televison & Video
Tv/vdr/cable box
Your hookup is correct- Your VCR needs to be tuned to channel 3 or 4, to match the cable box.
Also, the VCR channel output needs to be matched to the TV. If VCR menu options are displayed on the TV then this part is right. If not, then set either the VCR or TV to the correct channel.
May 11, 2008 | Sharp VC-A420U VHS VCR
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Supersonic FC2245 13 Color TV/DVD Combo Television Logo
162 people viewed this question
Top Supersonic Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jason Morris
Computer Repairing
Computer Repairing
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
