I am having the same problem as the people as before. My dryer is not heating up. I have check the back of it, clean the front filter and where sets in. Please HELP.
Thank You,
Theresa
[email protected]I am having the same problem as the people as before. My dryer is not heating up. I have check the back of it, clean the front filter and where sets in. Please HELP.
I have a ge profile dryer as well with the same problem, also knocked the belt off when I tried to repair it myself and cannot find a schematic for the belt. Model # DPXR473EWOWW. Please help.I have a ge profile dryer as well with the same problem, also knocked the belt off when I tried to repair it myself and cannot find a schematic for the belt. Model # DPXR473EWOWW. Please help.
I have the same problem; no heat, blower not working. Can you email me your service manual? Thanks, [email protected]I have the same problem; no heat, blower not working. Can you email me your service manual? Thanks, [email protected]
AnonymousDec 20, 2008
When I go into the service mode it states the blow not getting up to speed and the heater not working??When I go into the service mode it states the blow not getting up to speed and the heater not working??
My dryer also is not heating. Repairman came and said it wasn't the heating element, but he doesn't know what the problem is. Any ideas? [email protected]My dryer also is not heating. Repairman came and said it wasn't the heating element, but he doesn't know what the problem is. Any ideas? [email protected]
I have the same problem. Dryer not heating all elements tested and are working. Did anyone ever solve the problem? Please email me at [email protected]I have the same problem. Dryer not heating all elements tested and are working. Did anyone ever solve the problem? Please email me at [email protected]
i have the same problem with my dryer also.could you send me the [email protected]! i have the same problem with my dryer also.could you send me the [email protected]!
AnonymousJan 27, 2009
I also have the same problem as the people as before. My dryer is not heating up. I have check the back of it, clean the front filter and where sets in. Please HELP. My email [email protected]
Thank You, I also have the same problem as the people as before. My dryer is not heating up. I have check the back of it, clean the front filter and where sets in. Please HELP. My email [email protected]
This problem is chronic for the GE Profile dryers.....I need the manual as well: [email protected]This problem is chronic for the GE Profile dryers.....I need the manual as well: [email protected]
Our dryer will not heat up! its like it has a mind of its own sometimes it will sometimes it won't has anyone found out a solution?Our dryer will not heat up! its like it has a mind of its own sometimes it will sometimes it won't has anyone found out a solution?
will not heat and blower will not workwill not heat and blower will not work
AnonymousFeb 18, 2009
I have the same problem. Can you please email the manual? Thanks. [email protected]I have the same problem. Can you please email the manual? Thanks. [email protected]
I have the same exact problem. Can I please get the manual also. Thanks. [email protected]I have the same exact problem. Can I please get the manual also. Thanks. [email protected]
I have the same problem .. can you send me instructions on how to replace the heating element Thanks.. [email protected]I have the same problem .. can you send me instructions on how to replace the heating element Thanks.. [email protected]
My dryer is not heating up. The dry cycle does not dry. Please email me the pdf at [email protected]
Thanks!My dryer is not heating up. The dry cycle does not dry. Please email me the pdf at [email protected]
Thanks!
AnonymousApr 14, 2009
I have the same problem .. heating unit run sometimes and sometimes it don't, seem it runs from a cold start but once been used it wont run anymore send any solution to [email protected] Thanks
You can't post conmments that contain an email address.
I can email you the manual for the unit please post your email address and i will send it in PDF format you can print it off or look at it if you have dial up connection it may take awhile it is like 12Mb
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
If you have tried all the normal fixes for the harmony dryer you might be having a problem with your blower motor. To check, remove your dryer vent and start the dryer. If you have no air moving then your blower motor has stopped. When the blower motor is not running then your dryer will not heat. This is one of a few models that have a seperate motor for the blower so most techs will miss this. Good luck to you, [email protected]
as for a whirlpool lasting longer than a GE or Maytag, or whatever...they are, for the most part, all the same animal. Made by White Industries, once known as White Westinghouse, they produce nearly all of the major U.S. brand major appliances.Take your pick. Buy according to functions you really want, or need; the more gadgets there are, the more there is to go wrong.
Thank You,
Theresa
[email protected]
ME [email protected]
can you also send me the diagram my email is [email protected] Thanks
Please e-mail me the diagram, i really need this. [email protected]
Thank You!
GE DRYER - will not heat. Will heat every ten use,
I have the same problem [email protected]
I have the same problem can you email me as well [email protected]
Thank You,
Same problem here as well...Please send service manual...Elements are OK and blower will work from time to time.
[email protected]
I have the same problem...please help: [email protected]
dryer not heating or blowing
can you email me the same thing [email protected]
The dryer will not heat up every time. it works then it stops.
Dryer not heating. How do you get to the elements to replace?
My dryers' heater and blower are not working either, can you please send the diagram to [email protected].
Thank you!
Thanks!
Thanks
