The machine was acting funky, so I reinstalled the system software. Unfortunately, I can no longer access the machine through the windows network, any help would be appreciated.
https://es.wikipedia.org > wiki
· Translate this page
En el marco de la Feria Aeroespacial M?xico 2017 (FAMEX 2017) fue presentada una versi?n mejorada del 210A, el Pegasus P400T, esta aeronave cuenta con tren ...
You will have to get a disk recovery specialist to retrieve your data. The internal YellowBox system is Linux. The specialist will remove the disks and attach them to translation and recovery technology. It will cost money.
Yes, it must be attached to the network
0. Install the yellow machine software on the PC
1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8.
2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears.
3.Click Edit.
4.Select Yes to Enable LAN Interface. Default: Yes (Enabled)
• If you select No, all other LAN option fields are blocked.
• If you disable the LAN Interface, the only access to the Yellow Machine appliance is
through the WAN port. Anthology Solutions does not recommend this configuration.
5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled)
6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address
• Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine
appliance connects to either a router that has DHCP service enabled or to a cable
modem. This setting makes the Yellow Machine appliance a DHCP client on your
network.
• Obtain IP Address from ADSL provider is greyed out.
• Choose Static IP Address if your network is locally defined and controlled and does not
use DHCP services. Type the IP address manually.
7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply.
8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
go to the corel support site and Windows and look for software updates that deal with this issue, most likely there are patches to correct this, use Corel support 1st.
Is it just the fault led, let the machine run for a while and see if it starts rebuilding the drives, if it is NEW and you have just installed the drives and never installed the software then you will get a fault I have the q400t which is the platnum version tho they still call it the p400t if you have just received the server then what u must do is power off the server plug in the netcable into one of the 8 lan ports run the install till it tell's you to turn it on then hit next then follow the instructions to setup the server
You can download the drivers & software from the link below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10237
Choose the Drivers / Software red link & select which operating system you need the driver for. You can also download the "EasyPhoto" software & the manual if you need it.
Please update the question & let us know if the information given was useful to you - Good Luck!
