T osolve this problem, wait until your gogear device dies and wait for 3 hours. after that, recharge your device. This will occasionally happen to this device. (from personal expierience). I recomend the ematic tocuh screen ipod for only 65 $ on walmart. works very good
1 On your computer, select Start > Programs > Philips Digital Audio Player > Aria Device Manager > Philips Device Manager to launch the Philips Device Manager. 2 Turn off GoGear Aria before you continue. 3 Press and hold the volume button while you connect GoGear Aria to your computer. 4 Keep holding the key until the Philips Device Manager acknowledges GoGear Aria and enters the recovery mode. 5 On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process. 6 When the recovery is completed, disconnect GoGear Aria from your computer. 7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Try repairing the device: 1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website 2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
You may have to charge the device fully for 3 or 4 hours AFTER this process is complete.
Make sure you back up all songs on the GoGear before attempting this solution. 1) Back up all files on the GoGear 2) Open up Philips Device Manager (Start --> All Programs --> Philips) 3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
