Polaris ATV Logo
Posted on Nov 26, 2009
2003 polaris 330 magnum, when I turn on the key,I have lights, but the digital dash doesn't come on and it won't turn over......
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Dec 03, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
6571
Points
22
Do a load test on your battery... could be a bad battery
2answers
2005 Polaris Magnum 330 2x4 utility ATV. Where is the circuit breaker?
https://www.google.com/search?q=Where+is+the+circuit+breaker+located+on+a+2005+Polaris+Magnum+330+2x4+utility+ATV&rlz=1C1CHBF_enUS757US757&oq=Where+is+the+circuit+breaker+located+on+a+2005+Polaris+Magnum+330+2x4+utility+ATV&aqs=chrome..69i57.584j0j4&sourceid=chrome&ie=UTF-8
Apr 01, 2021 • ATVs
1helpful
Why will 2005 Polaris Magnum 330 fan not stop running when the ignition is turned off? The running fan drains the battery.
replace the faulty fan relay or check for a problem wire from the ignition to the sensor to the relay
Where is fuel filter? located
Polaris fuel filters are usually in the fuel line coming from the valve that turns fuel off. This model does not seem to have an inline filter, however you can always buy a universal one and splice it into the line so that then it does have one
Nothing works
Have you checked the fuse terminals coming off the battery there is a fuse some times it is a bad ground make sure battery is charged
2003 polaris 330 won't stay running with lights on
charge system fault
could be the charger ( alternator) voltage regulator or loose wires
indicates not enough power to run the ignition system when the head light is turned on
Nov 25, 2017 • Polaris ATV
1helpful
I have no lights no dash and when I turn the key over nothing battery is good
Have the ignition module unit tested, I had one go bad and it did the same thing. Eric
No awd only 2wd
If I remember right it does the little black box (not the CDI box) the 330 I replaced the control box on once i replaced the box the speedo did light up again been along time ago but I think if you repalce the control box it will fix your problem
Won't throttle up.
Repost under ATV for an answer
Top Polaris ATVs Experts
john h
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Polaris ATV Expert? Answer questions, earn points and help others
