Question about RCA F19625 19" TV
TV SOUND MY TV DOESN'T HAVE ANY SOUND PLEASE HELP
  • Anonymous Apr 15, 2008
    I went to menu and click audio on
Tv no sound
Posted on Feb 03, 2009
  • 83 Answers
This might sound daft but your speakers might have blow or if u are running cable/sky u might have muted it on that
Posted on Jan 14, 2008
6ya staff
SOURCE:
The TV works fine but doesn't have any sound.
Is this the initial set up or did the sound suddently stop working? The usual fixes: mute on/off? go to the menu and select "audio", check the settings there. if this is the initial setup, do you have the cables connected properly? if you are running HDMI/USB and or Optical cables, it can be confusing !!
Jul 05, 2013 | Element Electronics FLX1511B 15 in. LCD TV
My sound disappears
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
Nov 11, 2011 | Televison & Video
My Westinghouse TV LCD has no sound but has picture please help? 32 LCD westinghouse
Regards.
Oct 21, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I am using FRONTECH LCD TV BOX Model no JIL-0616 in with my pc. when i push PIP button it doesn't show a window on my desktop .i also tried by applying default settings ,but the problem was not not...
I am also facing similar problem. I see sometimes both TV and computer simultaneously, but dont know when it works or when it does not works. It is working randomly when i press pip button. Anyone know how to fix this? When it does not work, it says unknown resolution. I tried changing different resolutions but no use.
Aug 20, 2011 | Televison & Video
Tv sound only plays with dvd player not television.
problem in audio-video ( audio pin). clean this with tooth brush from inner site.
Jul 02, 2011 | Sanyo 42K30E 42 in. TV
Problem to turn on Philips TV
sound very much like the C.R.T is low emission the tv monitors the tube before showing a picture.either get the tube boosted or changed most tv shops should do i
Oct 18, 2007 | Philips 27PT563S 27" TV
Sanyo avm 2506 tv no sound
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Sep 27, 2007 | Sanyo AVM-2506 TV
RCA F19625 19" TV Logo
71 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
