Question about Audiophase MDP-1 Personal MiniDisc Player
Audiophase MP3 player charging
The Mp3 player showes it is charged when you plug in the USB port but when you unplug it it won't turn on!!!
  • Big T 1997 Jan 14, 2008
    Nope I found the problem on another web site I did not know when you charge it you have to have the switch turned on!!!
  • 83 Answers
Power u are getting to the mp3 player is only from the computer sounds like u need a new battery
Posted on Jan 14, 2008
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
Audiophase KZ111/Kz112
Turn the on/off switch to on while charging.
Feb 12, 2008 | Audiophase MDP-1 Personal MiniDisc Player
Unable to charge battery on Audiophase MP3, model KZ111
Try using the AC charger for the mp3 player, If It does the same thing, Ur MP3 is defective and u can return it with out the receitp sayin that it was a christmas gift since most eleftronics have a 1 year warranty
Feb 07, 2008 | Audio Players & Recorders
Trouble charging
1. Plug in usb cable to computer.
2. Plug other end of cable into MP3 player.
3. Turn MP3 player on using the power slide switch. The display should change slightly to indicate charging. (Mine has a picture of a battery that will fill and empty...) Hope this helps!
Jan 12, 2008 | Audiophase MDP-1 Personal MiniDisc Player
Charge battery
Try resetting the MP3 player. turn it on, connect to your computer press and hold the play button for ten seconds. unplug it wait 10 seconds and plug it back to your computer. leave it charging for a couple of hours.
Dec 29, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Audiophase mp3 -how do i charge?
just plug it into the usb port on your computer. you'll se the battery meter as it charges.
Oct 14, 2007 | Audiophase MDP-1 Personal MiniDisc Player
I had the same problem, so I got fed up and threw it against the wall...... Just kidding. I have a Motorola phone that uses a mini-USB plug-in charger. So I connected it to the mp3 player and plugged it in, looking for smoke. And Wala! it started to charge. The mp3 player has to be on. When you see a battery icon and it simulating being filled up, then you know that it is charging. Once it stops filling up, it's done. Good luck!
Also, if you use the USB cable in you computer, make sure that the mp3 player is on. I had absolutely no luck on charging this way, but maybe you can.
Oct 03, 2007 | Audio Players & Recorders
Audiophase KZIII 1GB not being recognize or working
Ok for the KZ111 and KZ100 audiophase. turn the mp3 player on. then plug it into the computer. the player will start charging. Go to windows explorer or my computer and you will see it listed as a hard drive. Create a folder called music. you can then drag and drop mp3 files into the music folder. As for charging the battery my Motorola V170 cell phone has a usb charger. I use it to charge my mp3 player takes about 20 minutes. and the charger in my car for the phone works too. Hope this helps.
Sep 04, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Mp3 Player Won't Charge
wiggle your usb cord - I had to wiggle mine a bit where it plugs into the usb port in the computer before it was recognized and listed as a device in 'my computer'. only then did it actually start charging; if your computer is not recognizing it is plugged in, it may not charge.. when i finally figured this out, the actual charging of my 4 gig audiophase mps only took 10 minutes- previously i was trying to charge it for hours without any luck.
Aug 31, 2007 | Audio Players & Recorders
Audiophase MDP-1 Personal MiniDisc Player Logo
67 people viewed this question
Top Audiophase Audio Players & Recorders Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you an Audiophase Audio Player and Recorder Expert? Answer questions, earn points and help others
