My 89 nissan maxima is not charging ive put 2 alternaters and a new battery and nothing also the check engine and the battery lights in the dash dont work and the bulbs r fine
CHECK YOUR COIL & CHANGE OUT THE NECESSARY CIRCUIT BREAKERS, CHECK YOUR RELAYS FOR THE DASH CONSOLE, THE FUSES FOR THE DASH CONSOLE/STEREO & HEADLIGHTS
sometimes jumpstarting can damage the computer.. I would try undoing the positive cable to your battery and leave it off for a minute to let the computer reset. Put it back on and try it again. If that doesnt work, Im afraid you will have to have someone check it out.. If an engine light is coming on, auto zone can check the codes for free..
when you go into reverse your reverse light switch comes on this could be your problem short in wiring or switch disconnect switch and see does it work
That has nothing to do with the voltage regulator. You need to check the WIRE from the ignition switch to charge indicator light. Seems like you may have an open circuit there. Get the wiring diagram for your charging system and check it out.
Removed the positve and negative charge of battery for 10 minutes then, plug it back the positive first then negative charge and the last step you do is to start the engine. This steps is to clear tcs off, slip and awd lights.
i have a 2004 maxima and overnight my battery seems to drain out my car dont start i have to my battery is brand new and i leave no lights on is there a solution for this ???????
