Question about Nintendo Wii Console
Wii controller wii remote...will turn on but blue light won't stay on. Batteries are new. Tried resetting remove..any ideas?
  • Anonymous Apr 26, 2008
    new batteries, but the lights blink like 4 times and that's it. WTF!!!
  • 83 Answers
Problem with hand set may be down to soft wear if u no any one any 1 else with a wii try it on theres
Posted on Jan 14, 2008
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
Cant get pass the "press A button" screen
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Sep 05, 2008 | Nintendo Wii Console
The ON button on the Wii remote doesn't respond. Tried new batteries but still no response. No blue lights, nothing! Tried patting it, reset button, all instructions as listed in troubleshooting. Had since...
Try reseting the wii console. This is done by removing the battery from the botton of the console. There is a small battery bay held in by 1 screw. Leave it out for a day and after you install it make sure you press the conect button on the wii. (located under SD card reader door). And the connect button on the controller (located in battery compartment on back of controller). Good Luck.
Nov 24, 2009 | Nintendo Wii Console
Bought brand new batteries for my remote, but
You need to re-assign to the Wii. When you first bought it you pressed the button on the front of the Wii to configure controllers, then the controller buttons to find the Wii. When you change batteries you need to repeat this process as the 'memory' of the controller to the Wii has been wiped
Nov 12, 2009 | Nintendo Wii Console
Our wii remote wont turn on. we tried new batteries and all it does is the blue lights flashes and turns off. What is wrong and how can we fix it
Sounds like it's not synchronizing with the infrared bar. That might've come loose. Double check to make sure that's plugged into the Wii. If that's not connected the Wii Remote will not stay on because it's not connecting.
Oct 14, 2009 | Nintendo Wii Console
Wii remote turns off
It sounds like you either have a low battery, or your motions may be dislodging the batteries on your controller. When the controller is off and you press a button, check to see how many of the four blue lights on the bottom of the controller are flashing. This tells you how much battery power you have: four lights is full, one light is low. If it's saying your battery is full, try taking the battery or batteries out and putting it back in. Good luck!
Jan 08, 2009 | Nintendo Wii Console
Wii remotes will not stay on
1. Press the Power button on the Wii console to turn it on.
2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
3. Remove the battery pack & install regular batteries.
4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
7. Quickly remove the batteries and reinsert your Battery Pack.
8. Return to Step 2 for each other remote.
You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
Dec 16, 2008 | Nintendo Wii Console
Wont power up, blue lights stay on have changed out the batteries
try resetting the remote and the console. in the console you open front panel and their is a red reset button press this firmly then remove batteries from back of remote press the reset on the console again. Then replace the batteries press the red reset on the console a third time and then push the red reset button on the back of the wii remote this should take care jof your problem.
Nov 14, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
21 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
