Question about Car Audio & Video
Car will not start
How do I get steering wheel column unlocked and ignition to turn?
    President:
  • 1,314 Answers
If its stuck grab the steering wheel and shake it back and forth while turning
Posted on Jan 14, 2008
6ya staff
SOURCE:
My steering wheel is locked and I can't start my car
if the ignition key does not unlock the steering column there is a mechanical problem inside the ignition lock cylinder or column itself. the steering column will have to be disassembled
Jul 26, 2011 | 1997 Honda Accord
I have a Honda CRV (2004) and the steering wheel is locked. The key will not turn in the ignition. Do you know how to unlock?
Try this.... Sit in the car and grab the wheel, pull or push the steering wheel with your left hand and arm, HARD! while turning the ignition.... Sometimes when you park with the wheels turned the weight of the car bears down on the wheels and has a tendency to lock the column!
Feb 14, 2010 | 2004 Honda CR-V
How do I take steering wheel column apart to get to ignition lock system? Currently, I am unable to turn on the car as the steering wheel is in a locked position and no action occurs when I insert the key...
You say no action, Does that mean the vehicle does not turn over? The vehicle turning over and the steering column unlocking are two separate systems. If you turn the ignition and nothing happens and have an alarm installed, remove the in-line fuse from the alarm power line. If it is the Interlock, you will need either a T-5 or T-10 driver with a recessed hole to remove the column cover screws. These are Torx Head Screws to make vehicle theft harder. I also recommend you get a haynes repair manual for your vehicle to guide you through the repair.
Nov 28, 2009 | 1998 Chrysler Concorde
I can't pull out the key it seem that the car locked the key and i cant start the car
Make sure the gear selector is fully in park, alot of times if the cars wheel was turned when the vehicle is parked the steering wheel is locked in the turn position and it puts pressure on the ignition switch. Try turning the steering wheel slightly left/right and see if it kicks back. If it does you have tension on the ignition and need to hold it until the key is turned to the on position and it unlocks the ignition. If you can try to let the wheel come to a rest before turning off the ignition as opposed to holding the wheel turned and shutting off the ignition, this will avoid a locked wheel/column
Aug 06, 2009 | 2003 Chevrolet TrailBlazer
Cant unlock steering wheel to start car
I would chalk that up to old age and wear and tear. I expect that when you take the steering column apart you will find a lot of play in the linkage between the ignition and the lock. These will probably be dealer only items to replace unless you can find them in a scrap yard. It will probably be easiest just to remove the lock mechanism and leave it that way. Just make sure that everything else works before you put the column back together.You may also be able to shim out the play with some time and patience if you can't find parts. Copper and brass work the best. Hope this helps.
Aug 02, 2009 | 1983 Nissan Sentra
Steering column locked
When you get the key into the ignition, Try turning the wheel to one side or the other as you turn the key. Some vehicle's steering columns will "lock" if the wheel is turned to tightly when the ignition gets turned off. Hope that helps.
Feb 23, 2009 | 1999 Chevrolet Monte Carlo
Hello, my steering wheel is locked! I tried wiggling the wheel and turning the key and that didnt solve the problem. Let me mention the ignition would not turn over in the first place, even when my car...
All you need to do is turn your steering wheel to the left all the way till it stops then put your key in while still holding the steering wheel to the left, turn the key to the on position this should release your steering wheel!
Jan 30, 2009 | 1998 Chevrolet Cavalier
I need to unlock the colume
Colume?  Did you mean "steering column"? as in steering wheel?  Usually turning the key in the ignition as you turn the steering wheel will unlock the steering column.  This may take some considerable force depending on the way the car is resting (on a hill, against a curb, with sideways pressure on the wheels).      Being more specific your problem will always yield a more helpful solution.
Dec 23, 2008 | 1994 Volvo 940
Remove steering wheel and steering column in 1992 acura legend
first , as you try to turn on the ignition , move the steering back and forth to release the pressure on the lock tab on the steering shaft
next you will have to install a safety pin to stop the air bag going off
there are 4 bots that hold the lock assembly onto the shaft but you will need a grinder to get the bolts out as they have no heads
it is easier to remove the steering column complete from the car to replace the switch
it is not really a diy job unless you have a workshop manual and some mechanical experience
Apr 18, 2017 | 1992 Acura Legend
Car Audio & Video Logo
134 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
