Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Hi, my door opener is sears/craftsman model #139.53603, 1/2h.p. . The door was a-ok then only opened about 3' I adjusted the travel limit setings and force settings and gained about 1' more travel. The mechanical mechanism is good all gears and bearings are not excessively worn and work well.
    President:
  • 3,197 Answers
It sounds like you have a broken door spring. Look closely - some breaks are hard to see.
Posted on Nov 25, 2009
How do i set the travel limits on my craftsman garage door opener 139.53919
  • Open the garage dooricon1.png fully by pressing the wall control button. The bottom section of the door should be right at the header in the "full open" position. If it is too far back, the door cable can become misaligned. If it is not back far enough, you may not be able to get your vehicle in and out of the garage.
  • 2
    Position a stepladder behind the garage door openericon1.png motor. Locate the limit adjusting screws on the left side of the motor housing. Have a friend stand by the wall control button.
  • Sponsored Links
  • 3
    Insert a screwdriver into the slot for the "up limit" adjustment screw. Turn it to the right to decrease the door travelicon1.png and turn it to the left to increase it. Turn the screw in small increments.
  • 4
    Close the garage door by having your helper push the wall control button. Notice the seal between the door and the floor--there should not be any light coming through. Adjust the "down limit" screw in the same way if necessary.
  • 5
    Operate the door by the pressing the wall button and check your adjustments.
  • Read more: How to Adjust a Craftsman Garage Door Opener ' eHow.com http://www.ehow.com/how_5419011_adjust-craftsman-garage-door-opener.html#ixzz2Hm1tx0a0
    Jan 12, 2013 | Sears Craftsman LiftMaster Chamberlain...
    I have a craftsman 3/4 garage opener. When it is traveling down it will contuniue past the adjusted stopping point and keep going untill it runs out of track and then travel back up.. It seems to only...
    It sounds like your door is traveling just a bit too far in the down direction. Locate the 'down limit' adjustment on the side of your motor unit and turn this control a bit in the opposite direction of the arrow printed on the cover. Some tweaking will then be necessary to get it just right.
    Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Craftsman garage door opener #139.53985 The door reverses in the fully closed position. I can not decrease the down travel limit by turning the adjustment screw clockwise. Please comment regarding a...
    TAKE OFF THE COVER & SEE IF THE LIMITS ARE WORKING CORRECTLY.
    IF THEY ARE AND THERE IS JUST NOT ENOUGH TRAVEL YOU MAY NEED TO REMOVE THE CHAIN AND REINSTALL IT 4 OR 5 LINKS OVER THIS WILL INCREASE THE LIMIT.
    HOPE THIS HELPS
    Jun 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Can the travel limits on a Chamberlain security+ be reset?
    If you are at the back of the operator looking toward the door the limit adjustment should be on the left hand side.
    The adjustment closest to the door is the down limit turn that 3 turns clockwise. The adjustment screw furthest from the door is the up limit turn this screw 3 turns counterclockwise. That should get you close to factor settings. If this does not work; remove the cover on the operator sometimes the limit assy. come apart.
    Oct 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
    My door opener is new, Chamberlain, mod cg40cd, the drive will hit both limits. will not let me set the up and down limits, doesn't seem to matter whether I set the up and down to max either way??????
    THE TRAVEL ADJUSTMENT IS ON THE SIDE.
    YOU MAY BE ADJUSTING THE SENSITIVITY (TRAVEL LIMIT HAS NO MAX ADJ.)
    BE SURE TO RESET THE SENSITIVITY ADJUSTMENT TO ABOUT 1/4
    HOPE THIS HELPS
    Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Craftsman 1/2hp garage door opener does not go down to floor
    I'm no expert, but on a previous door opener I had (don't know the brand), the side adjusting screw basically adjusted a limit switch, which was located inside the plastic housing (where the motor is). I was able to remove the housing, figure out which limit switch was actually being contacted "too soon" on the way down and adjusted it while watching it.
    Just a suggestion, you might take a look.
    just keep your hands out of the way of the chain and sprocket if you do take the housing off. .
    Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Craftsman GDO, Model 139.53600. moves 4inches up/ down
    Find the increase travel adjustment screw and turn it clockwise 1/4 to 1/2 turn.
    Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman 3/4
    Open up the caseand look at the travel assy. Sometimes the limit (up or down) do fall off the assy. Just snap it back on.
    Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
    3/4hp craftsman will not close the door fully
    There are adjustments on the unit itself that control the distance door travels to close as well as the force it uses to close. The info and location of controls is indicated in the manual that came with your unit.
    Apr 12, 2017 | Sears Craftsman LiftMaster Chamberlain...
    GARAGE DOOR OPENER
    Refer to your owners manual to adjust the travel limits to stop the door opening too high
    Apr 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    160 people viewed this question
    Top Sears Building Materials Experts
    Mike
    Steve Allison
    Steve Allison
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
