Question about Epson Stylus Photo R800 InkJet Printer
Epson r800 inkjet will not turn on
After 2 years of normal use (?) my epson R800 printer will not turn on.
  • 2 more comments
  • Anonymous Jan 18, 2008
    I have the same problem after 6 months. Could be the on swich button but having trouble getting casing of to check contact points for button. Ill keep trying to locate screws so I can remove the casing.
  • Anonymous Apr 17, 2008
    I turned the printer off as usual.  Then when I went to turn it on again about 5-10 minutes later, it wouldn't go on.  I checked the cord & unplugged it from my outlet & plugged it in again.  Still doesn't go on.
  • Pauile Jun 26, 2008
    Piece of ****. For years I have had the same problem. Sometimes it turns back on in a couple of days. Once it took 4 months. I'm just disgusted. The printer has a bad power supply and Epson refuses to acknowledge the problem
  • cashccmepayp Aug 16, 2008
    This is a larger problem than I thought...My first Epson R800 lasted a little over a year before I turned it on one day and when I glanced back at the printer it had somehow turned itself off...i depressed the button and got no response at all, I checked the wall outlet secure and resecured it..Getting angry i removed casting carefully..and began testing everything one by one as i dismantled the print.Looking for any sign of physical wear or tear..And also attempting to restart printer after each part was removed...prosses took 10 hours total..my printers response was every time i would unplug it for an hour, then plug it back in it would begin to power up for around ten seconds then like clock work it would return to it nonworking state and i would not be able to get the printer to do that or anything at all..untill i unpluged it for an hour the restarted..would i get to see the attempting of a start up.....physicaly i saw and smelled nothing adnormal on any of the inner workings of the printer...it is now spare parts for a new epson r800 that i purchase 2 weeks ago..........now this is my problem ok..that printer was working fine untill the identical problems withprinter 1 started happening to printer 2..and no i did not take printer 2 apart at all it is still 3 weeks old mint condition exept for the it wont turn on problem....What do I do"? can anyone please tell me how to fix this thank you for reading my please help post
I leave mine unplugged overnight. Next mornig I plug it in, turn it on and restart Windows. Give it a shot.
Posted on Jun 07, 2008
Don't try to remove the casing, get it serviced. Trust me it is not a problem with the switch.
Posted on Mar 13, 2008
Single paper sheet not printed, multiple yes
Try few steps as given below...
1. poor quality printer may reduce printer quality & causes paper jams and other printer problems. If you encounter problem , switch to a higher grade of printer.
2. Do not load curled and paper folder.
I hope, it helps.
Feel free to get instant printer help at http://www.vtechsquad.com/printer-support/ to fix any printer issues.
Jan 21, 2013 | Epson Stylus Photo R800 InkJet Printer
I HAVE a epson stylus photo R800 printer. I cleaned the printer head using both the automatic and manual settings. The test pattern improved greatly, but still leaves the seventh pattern incomplete. ...
if after doing 6 head cleanings and its still the same issue, that only means that the printer is already having a hardware issue, the printer is totally broken
Feb 11, 2010 | Epson Stylus Photo R800 InkJet Printer
Epson stylus photo R800. I need to replace the paper guide front assy.how do i do it
You asked me to join your Premium Assistance Plan to solve my Problem!
now you ask me to tell you how I solved it, Well maybe you would like to join my Premium Assistance Plan and I will tell you
Many thanks
Dec 25, 2009 | Epson Stylus Photo R800 InkJet Printer
I am looking for a free service manual for the Epson R800 or just the assembly & disassembly section
Here is a link to all drivers, software and manuals for your printer.
Hope this helps.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=30501&infoType=Overview
Nov 07, 2009 | Epson Stylus Photo R800 InkJet Printer
R800 won't turn on
1. make sure all power cables are securely connected.
2. check connection to pc from printer.
3. Plug the printer into different outlet (one can go out while others still operate normally, it happens!.....even on a surge protector!)
Apr 19, 2009 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus Photo R800 (Manual Feed) missing option
I found this answer on Apple.com support discussions.  Worked for me.  There is more information available on the discussion, but this was enough to fix my problem. Try Page Setup. Select to format for your printer. The choices for different all media should now be available under the Paper Size. This is a change from previous practice of creating a separate printer for each type of media.
Matt
Sep 22, 2008 | Epson Stylus Photo R800 InkJet Printer
R800 stopped printing-
MAke sure printer is directly hook to computer using usb, trash and reinstall the driver, that should fix it
Apr 04, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson R800 prints very wet, very very smeared pictures
it depends on the type of paper you are using. it is how the ink chemicals react to the chemicals on the photo paper.
Jan 01, 2008 | Epson Stylus Photo® R800 InkJet Printer
Epson Stylus Photo R800 InkJet Printer Logo
774 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
