Question about Dryers
New dryer (Maytag Bravos MED6400TB0) will not heat but the dryer I just replaced works great
I just replaced a Frigidaire Dryer with a new Maytag dryer. The Frigidaire works great but the Maytag does not heat. I am hoping there is something that I can check out myself without involving the warranty people. I bought a new cord and since I have a 3-prong plug, that is what I used. I have tried resetting the circuit breaker a few times and that doesnt seem to make a difference. I did shorten the vent hose.
  • Anonymous Mar 27, 2014
    maytag bravo dryer not heating
AF warning comes up during the drying cycle. What is this?
Posted on Feb 03, 2008
What can i check to see why my maytag bravos dryer isnt drying?
[Always disconnect the dryer from any power source before checking.] Dryer heating circuits have several parts in the series circuit that must all work (kind of like a string of Christmas tree lights) so you'll want to check each one in that series. These likely include the motor switch, timer switch, temperature selector switch, temperature controls/thermostats (usually three of these) and all connecting wiring plus the heating element. Of course, one should always make certain the dryer is receiving 220 volts power supply from the wall outlet before starting to troubleshoot the dryer. Most dryers operate with 110 volts, only using the 220 volts for the heater circuit. A dryer getting only 110 volts could run, but not heat. This doesn't happen often, but is always worth checking.
Aug 20, 2014 | Maytag Dryers
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Jul 31, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Thermal limiter maytag bravos dryer
a thermal limiter is a safety switch designed to keep a dryer from overheating, by either shutting off the heating element or the dryer itself if activated. They don't normally need replacing (unless you know your dryer overheated and activated it). If you have no heat in your dryer, chances are you have a bad heating element--the most common dryer problem
Jan 01, 2013 | GE DSXH47EGWW Electric Dryer
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Brand new gas dryer, drum will rotate, no heat produced. All electronics OK. No fuse or circuits blown. Maytag Bravos MGDB850WQ. Gas dryer, converted to LP. We have not been able to install to get it...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Dryers
Dryers Logo
409 people viewed this question
Top Dryers Experts
Marvin
Marvin
